Hello,
I have VCR Panasonic NV-FS200EG (PAL) and I have a problem with the video quality for a few minutes after the first start...
The video is smooth and stable (I think there will be no problem with the video head), but there is a green tint.
The video is fine, but the image is very green (for example blue sky is "green sky").
After some time (a few minutes) and changes (rewinding the cassette, stopping, playing), the green tint disappears and the picture is perfectly fine.
I believe the problem will go away with warming up (but I'm not sure).
Do you think it could be the capacitors causing it?
I am attaching a photo of the source part. There was a lot of dust and grease, so I vacuumed it up for now.
It looks better now, but still some parts are optically bad.
Thank you very much for the suggestion...
