06-07-2023, 06:15 PM
techiegirl techiegirl is offline
I wonder if anyone can help in trying to figure out why the above unit does: Format the HDD with using the skip codes shift 079 and the unit shuts off, same with SKIP 013. The unit see A hard drive but when using the skip codes, it shuts off. This would be with sata drives, both 2.5 and 3.5... Tried using wiped hd complete clean, no go, used fat 32, no go, tried NTFS drive, nogo all just shut down
The digital tuner works fine and I can see channels great.
Any help?
06-08-2023, 05:01 PM
dvd/hdd combo recorders use Ext2 (or 3 ) file system (like linux). I don't know this unit to help further
06-08-2023, 05:52 PM
Thanks :-) I did format one of the drives as Ext2 and it still just shut down the unit after trying to format the HDD. The unit see the drive as it shows in the menu and says some weird statement "This system is unconstruction of the file system"
Then the menu shows:
HDD format start: enter
Power off: Power
then I hit enter on the remove the unit shuts down. see attached files
06-08-2023, 07:04 PM
Many also use customer file systems, and often won't even boot without a correctly formatted drive inside.
dvr, magnavox
SV-5000W shuts down after play or eject? joonas Video Hardware Repair 4 10-15-2022 03:14 PM
JVC HR-S7800U Will Not Play and Shuts Down pumapuma Capture, Record, Transfer 2 01-20-2016 01:57 PM
Magnavox H2160MW9 record error slsdoug Capture, Record, Transfer 6 10-10-2012 01:30 PM
ATI All In Wonder card TV wizard locks up and shuts off pbd2012 Capture, Record, Transfer 5 04-01-2012 08:51 AM
Magnavox DVD player to a Magnavox recorder, won't work lordsmurf Capture, Record, Transfer 0 08-20-2011 09:39 PM
