05-21-2025, 07:45 PM
jham55 jham55 is offline
This deck was cleaned including the mode switch. Brand new tape loads well but will shut down. It appears to loose reel tension on the left side.eject works fine. I added a video. Any thoughts, Otherwise its pretty clean.
05-22-2025, 06:22 AM
timtape timtape is offline
I'm not familiar with that deck but I'd check the small braking pads are all intact and pressing against the reel tables as per normal. Also that in Play mode, there is take up tension and supply reel back tensioning. The tape should never form a loose loop.
Sony EV-C100 output has green, purple color? NKP765 Video Hardware Repair 1 03-30-2025 06:39 PM
Sony EV-C100 lights flashing? jham55 Video Hardware Repair 5 12-29-2024 12:14 PM
Sony EV-C100 Hi8 playback issue? jham55 Video Hardware Repair 7 10-12-2024 08:07 AM
Digitize 1/2" reel-to-reel tape? jgonc12 Capture, Record, Transfer 4 03-25-2024 06:03 AM
TBC recommendations for Hi8 capture using Sony EV-C100? theugster Capture, Record, Transfer 8 08-15-2020 10:47 AM
