12-13-2023, 10:30 PM
sawing14s sawing14s is offline
I recently had distorted playback on a hi-fi EP tape (that I know is not damaged). I didn't trust the AG-W1's "auto cleaning head" feature (I read that it's just a little wheel that eventually gets dirty) so I used a head cleaner tape with some drops of MG Chemicals 407C. I waited a few hours before playing a tape again, and now it only plays linear audio on every tape, no hi-fi whatsoever.
Is this the type of situation where I may have to open the unit and use chamois swabs and rubbing alcohol on the head drum?
12-14-2023, 01:44 AM
timtape timtape is offline
Hard to say what is going on. Head cleaning tapes were inferior to a proper manual clean as a technician would do. Cleaning tapes never really clean the tape path properly. Was the head cleaning tape designed for both wet and dry cleaning? Was it designed specifically for that cleaning fluid?
At best I guess the heads have somehow been made dirtier than before. At worst a hifi related head(s) has been damaged. If you can, have a skilled person open up the deck and check it out.
ag-w1, hifi, panasonic, vhs
Panasonic VCR bad linear audio? pthebest19 Video Hardware Repair 19 08-22-2023 07:43 AM
AG-1980 suddenly only plays HiFi tapes in linear mono? FF3D Video Hardware Repair 4 07-30-2021 08:24 PM
Panasonic 850 linear audio: hiss and dropouts, cause? Koen Video Hardware Repair 23 04-07-2021 11:20 PM
JVC SR-V10U head cleaning? JT_too Video Hardware Repair 1 02-15-2014 12:45 PM
Panasonic AG-1980 linear audio, s-video? DeeSeven Capture, Record, Transfer 4 09-26-2013 11:48 PM
