06-08-2024, 12:49 PM
Out of curiosity, have you tried different kind of tapes like PAL,Secam, NTSC and also SP and LP (different speed= different heads are in action)
The following users thank themaster1 for this useful post: d4vid4 (06-09-2024)
06-09-2024, 01:59 AM
d4vid4 d4vid4 is offline
I had the board out, could find no bad solder joints, leakage sign etc...
A few other problems appeared.
This machine is toast. Going to scrap it.
Thank you to all who read and replied.
David
10-01-2024, 10:30 PM
Other problems have now been sorted and am back to where I was before.
Yes, PAL and NTSC in both SP and LP. Same issue.
More like "on screen display" that's something else.
The "vcr-inside-a.jpg" attachment shows a "On Screen" area next to the "Servo" area on the mainboard with a chip and three capacitors.
I say it's a bad capacitor on the luminance demodulation or could be bad soldering or corrosion, just a guess
Where exactly would the luminance demodulation be located ?
What letter would the capacitors start with ? "L" "C" ... ?
(Again, I do not have the service manual, nor can I find one.)
Cheers,
David
10-03-2024, 08:40 AM
Here are some images to show the display problem in some more detail.
No VHS tapes were in any machine for this test.
1) The first image shows the internal Philips vcr menu on the tv (output image is okay) Philips --> TV
2) The second image shows another vcr (Samsung) menu on the tv (output image is okay) Samsung --> TV
now...
3) The third image shows the Samsung menu being sent to the Philips vcr (via Aux in) and the Philips vcr sending the Samsung menu image to the tv (output image has problems) Samsung --> Philips --> TV
It seems when the Philips "processes" any video being sent to it (via Aux in or VHS) it had display problems.
What area of the machine would I need to start looking at ?
Cheers,
David
10-07-2024, 05:22 AM
I have added a video (10 seconds) showing the bleed / image smearing when the image gets more light (white) in the picture and how the video starts to distort.
Video was generally okay before the image showed light/white colours.
I have also included three screen captures from the attached video.
Thank you very much for any help and pointers you can give.
David
philips, vr76775
Philips VR969 automatic head cleaning, now no picture? michelhammamet Video Hardware Repair 9 01-08-2022 07:35 AM
Strong bleed along edges? What is this? BeerOnABeach Restore, Filter, Improve Quality 3 12-21-2021 12:17 PM
JVC HR-S7900U Chroma Bleed? janame Video Hardware Repair 1 06-07-2020 04:53 PM
How to clean up color bleed? drzapp Restore, Filter, Improve Quality 12 01-27-2019 11:01 PM
Chroma bleed on capture? milosz Restore, Filter, Improve Quality 14 02-20-2017 03:09 PM
