08-13-2024, 09:34 PM
jham55 jham55 is offline
Hey there.. I have a VO-7600 umatic and I have changed all the belts. I removed the carriage and have tried to play a tape and it struggles to pull the tape. I can get it to play a bit but will shut down. I noticed that the T tension regulator arm when it is threaded bounces alot. It does not do that on my other 7600. Also when I power it on it goes to stand by and the other does not. I cannot find a service manual. Anyone have any ideas? It has to be something with the reels in that area.
08-14-2024, 03:00 AM
for the tension: see 17.30 min mark
https://www.youtube.com/watch?v=TNXLdIxw5pY
If you changed the belts with original belts it should work, if chinese cheap /thin belts i guess it's slippin' / not enough torque power ; with a more thorough cleaning maybe (old gum.) ...
08-14-2024, 04:07 AM
timtape timtape is offline
The problem could be the deck. It could be the tape. It could be a combination of both.
08-14-2024, 07:37 AM
Well its definitely not the tape. I have 2 of the same models and one plays the tape perfectly and the other does not. I think its the T tension regulator arm. It is loose. I cannot see from the service manual how to tighten that. There is an adjustment but it does not stay.
Sony VO-9800 Alignment issue? jham55 Video Hardware Repair 3 08-31-2024 08:58 PM
Best way to fix bad tension on tapes? FSquared Restore, Filter, Improve Quality 3 04-19-2020 03:44 AM
Issue with newly purchased Sony DVD+R MOTO Blank Media 5 09-02-2019 06:11 PM
Sound does not work with ATI All-In-Wonder 7600 AGP? Mazufa Computers 13 08-13-2019 11:25 AM
Tension Band Brake on Mitsubishi HS-U80 AnalogToTheFuture Video Hardware Repair 3 07-20-2017 03:29 AM
