12-10-2025, 06:02 AM
Meiereika Meiereika is offline
Hi,
over the weekend I digitized a VHS tape. It’s an LP tape.
After the tape had finished running, I rewound it all the way to the beginning. Now the player won’t eject it anymore.
Here is a video demonstrating the issue:
https://youtu.be/jGKV0I9Cu_0?si=LRUvx6k1BSgdhWti
Can you estimate whether the tape can be removed with a simple intervention, or whether this really requires an expert/technician?
Best regards,
Daniel
12-10-2025, 09:59 AM
Dirty Mode switch, they're fairly simple i recall (i've worked on sv-451, sv-422 etc..)
12-10-2025, 11:38 AM
see attached picture.
Try to put some grease on the gears too
eject, issue, samsung, tape, vcr
JVC HR-6955 S-VHS won't eject tape? Rubycon Video Hardware Repair 2 12-20-2021 03:36 AM
Panasonic AG 1980 wont eject tape. waloshin Video Hardware Repair 8 05-14-2020 02:27 PM
Bought a Sony SL-HF900 with tape eject problems? waloshin Capture, Record, Transfer 3 02-18-2020 07:39 PM
Samsung SV-5000W world vcr tape won't eject? waloshin Video Hardware Repair 1 09-30-2018 04:32 PM
JVC HR-S6900U turns off after tape insert or eject? Y4BB Video Hardware Repair 6 08-14-2018 10:06 AM
