F 04: check the loading motor drive circuit, check mechanism phase alignment (timing),
H 01: cylinder lock detected, cylinder does not start >> check the cylinder motor drive circuit
H 02: check the capstan motor drive circuit
F 03: check the loading motor, check mechanism phase alignment (timing), check the mode switch.
F 05: check the capstan motor drive circuit, check supply/take-up reel pulse
F 06: check the loading motor drive circuit , check the mechanism phase alignment
F 07 Rec power voltage does not appear in rec mode >> check rec power supply circuit
F 08 rec power voltage appears except rec mode >> check rec power supply circuit
F 09 no serial clock transmission between IC6001 and IC 7501 >> check serial clock circuit
