05-19-2026, 01:47 PM
Speedy77 Speedy77 is offline
Hey there!
I've been having a (truthfully) lovely time carefully disassembling my newly purchased Panasonic AG-1980p for a recap job this week. I was very happy to come across i86time's cap list and run-down of his experiences recapping his unit, along with aramkolt's wisdom along the way. I was even happier to find that nearly all of the boards i86time had in his machine were the same models and revisions as mine (besides my main board which was a A-7 instead of an A-6). I plan on replacing all the caps in the unit, which I realize to many is a bit of a fool's errand, but I find it a fun challenge and like to eliminate any possible reason to have to take it apart to service these very difficult-to-reach parts in the future. I also like the idea that some of the now-defunct functions of this unit work, like the analog TV function.
Having said that I had a few questions, particularly about getting to some of these caps on the boards. As of yesterday I fully disassembled the machine and was able to get all of the daughter boards off the main board (by some miracle the only damage that was sustained was a small chipped piece of plastic from one the notoriously difficult-to-remove connections between the I/O Pack board and the main board).
Forgive me if some of these answers are obvious, but I'm curious for those who have disassembled and/or recapped these units:
1.) Do I have to desolder all of the I/O connections in order to remove the small black back panel cover to get to the caps on the I/O Pack board or do I just sneak them in/out in-between? The black plastic tabs on the back of the PCB that poke through look slightly melted as if the board was soldered in place while the plastic was there, which I find interesting.
2.) Do I completely desolder and remove the little board from the risers on top of the Audio 2 board to get to those caps? I assume yes but just had to ask.
3.) The VHF/UHF input/output board that connects through the back appears to be simply soldered to the board and does not need to be desoldered correct? This seems obvious as well but I would just like to service the necessary parts as safely as possible.
Thanks again to this dedicated community. Can't wait to get this up and running again!
Panasonic K Mech pinch cam disassembly busted? MrPete Video Hardware Repair 15 08-18-2024 02:23 PM
Panasonic NV-HS1000 front panel disassembly? Sad_droid Video Hardware Repair 2 10-05-2023 03:09 PM
Panasonic AG1970 chroma board recap? brandonpaterno Video Hardware Repair 5 06-14-2022 06:21 PM
Panasonic AG-1980P Y/C board recap? (replaced capacitors) x77x Video Hardware Repair 14 10-21-2015 04:35 PM
Panasonic AG-1980 VCR repair - Which boards to recap? dpalomaki Video Hardware Repair 3 02-17-2015 07:21 PM
