03-20-2012, 05:14 PM
Giana Giana is offline
DVD recorders not only need to playback commercial DVDs with the highest video quality, but they also need to record video on a DVD and play it back with the highest quality. The input signal can be TV signals (which often are noisy—especially in the case of U.S. analog cable), low-end VCRs and analog camcorders. This variety of incoming video signals represent a colossal challenge for the DVD recorder designers in terms of signal tracking, input filtering and optimized video compression.
http://www.eetasia.com/ARTICLES/2004...MSD_EMS_TA.PDF
03-20-2012, 05:36 PM
Originally Posted by Giana View Post
http://www.eetasia.com/ARTICLES/2004JUL/B/2004JUL16_MSD_EMS_TA.PDF
Sorry LSI Logic DVD Recorder
03-21-2012, 02:42 PM
I'll assume there's no question here.
Thanks for posting and sharing this. (And for properly attaching the PDF to the forum.)
It's very interesting.
03-21-2012, 08:54 PM
robjv1 robjv1 is offline
Very cool, this was a fun read. I'd love to see more documentation and info on the chipset used in all the swanky DVD recorders.
03-23-2012, 08:08 AM
Thank you. I'm happy to help.
LSI is fantastic.
A home to record from TV using a Liteon LVW-5026.
The DVDr has no DVB. Using a digital decoder connected to the Scart video.
Yesterday they would play a show with a lot of video noise.
Registered with the Liteon in LP mode and the noise was gone.
Incredible.
Liteon has not, however, s-video IN
Liteon is less than JVC, but it does its job
The following users thank Giana for this useful post: lordsmurf (03-24-2012)
03-23-2012, 04:35 PM
jmac698 jmac698 is offline
I believe I can add to this discussion. The reason that DVD recorders can record the distorted timing of VCR's has a lot to do with the influence of an engineer, Ronald Snoeck. He investigated this problem thoroughly and then worked as a consultant to electronics companies to ensure that they could record VCR's properly. He explains in his webpage why the VCR timing is different. This is useful knowledge for what a TBC must address.
http://www.ronaldsnoeck.com/vcr.htm
The following users thank jmac698 for this useful post: lordsmurf (03-24-2012)
03-24-2012, 04:28 AM
Strange. I don't recall any NTSC models lacking s-video. I'm guessing you may have a PAL model?
The PAL models probably focused on SCART (RGB), which is technically superior to s-video. RGB is essentially component video (though not identical).
Note that SCART only handles SD video. Component carries HD, too.
Coax is worse than
< composite, which is worse than
< s-video, which is worse than
< component or SCART (both RGB formats), which is worse than
< HDMI
03-24-2012, 05:26 AM
Coax is worse than
< HDMI
In the instructions of the LITEON LVW-5026:
"Connection of a decoder," notes
1) When connected to the decoder, there will be a signal output S-Video recorder dvd if the dvd recorder is turned off.
2) This dvd is not compatible with S-video input signal on the SCART socket.
"Recording from VCR" Note As to point 1) above
JVC DR-M10 has scart s-video input
03-24-2012, 05:46 AM
The technical specifications of the manual is written: SCART2: CVBS / RGB in
LSI chipset (DVD recorders) gallery? lordsmurf Capture, Record, Transfer 12 03-27-2025 01:33 PM
LSI Logic chipset DVD recorders, useful to restore VHS videotape quality lordsmurf Capture, Record, Transfer 1 07-22-2011 06:42 AM
Organic HD DVDR dyes - white paper pepst Blank Media 4 02-14-2011 11:02 AM
WP: How are DVDR DL media made [white paper] pepst Blank Media 0 12-10-2010 09:29 AM
