11-20-2019, 04:25 PM
arjwalker arjwalker is offline
Hi Guys,
I'm really struggling and hoping you guys might be able to point me in the right direction...
As you can see from the attached image we have a laptop thats running dyno software which is the split and sent to 2 different screens (one for the customer to see and the other we use in the unit)
We then have a DVR which goes to one screen which is in the unit)
What im looking for is some way (with additional hardware or software) that I can display the DVR feed over the top (or PIP) of the dyno software so that it shows at the same time for the customer BUT also so that its recorded so that we can give a copy of the dyno run & DVR to the customer to view as they please. Would also be good if I could have out logo on the export too..
Im hoping that all makes sense!
Thanks in advance
Ant
11-21-2019, 06:59 AM
I've seen various hardware over the years, for something similar, though SD. However, I know HD exists, I just don't use it, don't recall models offhand. It's essentially surveillance industry stuff, standard fair I'd think.
Good s-video calibration source? swiego Video Hardware Repair 7 04-07-2018 08:01 PM
How to connect video source (RCA) to video card videoconverter11 Capture, Record, Transfer 1 06-01-2016 09:00 AM
Attempting to calibrate capture input, is the AVT-8710 a good source Prelude Capture, Record, Transfer 2 02-23-2015 09:36 PM
Do you keep your source material after capture? premiumcapture General Discussion 6 06-15-2014 07:39 AM
Multi-monitor setup for editing video? Two LCDs or mix of LCD/CRT? VideoTechMan Computers 8 06-20-2012 12:33 PM
