03-11-2020, 08:48 AM
mountaincabbage mountaincabbage is offline
Hi guys its been a while,
Working on a project at the moment where I am digitising VHS tapes, but I'm getting some dropped/duplicated frames which is causing some issues in my post processing.
Is there a capture method that ensures each frame is captures from the VHS? If a frame is dropped it just inserts a empty frame rather than miss it out?
Thanks,
Sean
03-16-2020, 04:29 AM
Eric-Jan Eric-Jan is offline
Thanks,
Sean
Why no info on what you're using ?
HD capture issues with Intensity Shuttle: audio sync, dropped frames? koberulz Capture, Record, Transfer 5 12-04-2017 08:43 AM
Dropped frames - What difference does frame synchronizer/TBC make? premiumcapture Capture, Record, Transfer 6 08-12-2014 10:37 PM
What are chances an external frame synchronizer tbc improves a signal with no dropped or inserted frames in vdub? quad4k Capture, Record, Transfer 0 07-23-2013 11:23 PM
How do you judge if a video capture is good? Dropped frames? Eagleaye Capture, Record, Transfer 2 07-17-2013 10:56 PM
Looking for VHS capture advice-CBR/VBR, bitrate, res upconversion, dropped frames jtrevor99 Capture, Record, Transfer 9 09-06-2011 03:23 AM
