03-20-2020, 12:06 AM
Guyz92 Guyz92 is offline
Hi all,
I just registered as new member in this forum. I would like to seek for help and assistance regarding suggested instrument or the best way to convert VHS to DVD for a good video quality.
For your information, I had two sets of PAL VCR (consumer version), which were Sony VCR SLV-KH3PS & JVC VCR HR-J781AM, for which both had only composite output, two sets of Panasonic DMR-ES10 for pass-through, and 1 Hauppauge HD PVR. Usually, when I convert VHS, I used this method which is direct from VCR to DVD Recorder. However, I realised that the DVD quality produced is not satisfactory.
I would like to inquire on three issues:
First, can anyone suggest to me a suitable PAL DVD recorder that can generate good video quality? Is Panasonic DMR-EZ49V a good choice?
Second, if I want to get digital video to be transferred to my computer to be processed later, I’ve been using Hauppauge HD PVR. This unit produced m2ts, ts and mp4. I usually chose progressive output setting on my DVD Recorder. Then, I used a component cable to get the progressive video quality. Is this the best way to get good video quality? Is there any other way that you may suggest?
Third, can anyone suggest a good PAL VCR that can easily be obtained from e-bay? I would really appreciate your help. Thank you in advance.
03-20-2020, 12:21 AM
DVD is lossy, you will not get good quality out of it, Capture lossless in AVI using the same capture hardware (Hauppauge HD PVR and ES10 passthrough) but with Vdub program instead and convert later to DVD if needed.
03-23-2020, 10:21 AM
^ The Hauppauge HD PVR is an H.264 hardware encoder with no way to capture lossless.
I would capture Interlaced, not Progressive from the DMR-ES10. I'm assuming its deinterlacing quality is similar to the ES15 & ES25, which sucks.
Take a look at the VCR Buying Guide and see whether any of those models are available in Malaysia.
JVC HR-S3800U Troublshooting/Repair Assistance Requested darkchylde_ Video Hardware Repair 0 10-18-2016 03:52 PM
Best Windows hosts? - Need assistance for setting up a development environment christiwilsonc Web Hosting 7 12-29-2011 04:03 PM
Need assistance with Procoder (newbie) MPEG encoder unclescoob Encode, Convert for discs 7 07-17-2011 07:41 PM
