03-29-2020, 08:40 PM
benzio benzio is offline
I use to capture my important tapes multiple times to make a median of captures, and I notice that sometimes, not always fortunately, the first capture is okay, and then in the second capture there is a lot of tracking problems... I started having suspects, then I extracted the tape during the tracking issue and I was horrified: (see images)
It wasn't already there in the first capture, I'm quite sure, because after the VCR plays the tapes, many has the same wrinkles in the problematic spots.
My JVC HR S9600EU is damaging my tapes.
And who knows how many was damaged... I'm aware of that because I multiple capture only the most valuable.
What may cause this?
I examined the pinch roller and seemed ok... But maybe is not... What else can be??
Is there a way to try to recover those tapes?
03-30-2020, 08:25 PM
keaton keaton is offline
Do a forum search on "feathering", and you'll see a few discussions on this about JVC models. This also happened to me with a JVC I acquired, but resolved it by adjusting my alignment of the video head drum. I cannot recall if adjusting the A/C head alignment was necessary. It's been too long. But that may have some impact as well. I was fortunate, in that the edge of the tape that got feathered did not have any information on it that prevented clean video and audio playback. It still played just fine in other machines and also in my JVC with fixed alignment.
Where in the tape path this happens is on the last guide that the tape travels across before going into the take up reel (on the right side when facing unit from front). For JVC, the top of this guide has a "bulge" (for lack of a better term that escapes me), which many other manufacturers don't have. When the tape rides too high, the top edge of the tape will roll up over this "bulge", which is not what the design intended. This causes the "feathering". After I got my alignment fixed with proper studio released tapes, it still took me a while to put the lid back on until I trusted the tapes would not be feathered any more. A bit of anxiety to overcome, of course.
Adjusting alignment is something that is normally not encouraged to do. Naturally, there are very few that would likely be able to do this for you. And it could cost quite a bit. But this is very likely a symptom of poor alignment and you don't have much choice in getting it resolved, I would venture to say. Wait for more replies and do some research before attempting though. lordsmurf has posted a thread on here about how to carefully go about this on your own. http://www.digitalfaq.com/forum/vcr-...c-vhs-vcr.html
I managed to do this, and it was my first time, but I did some research and was careful. JVC's are easier to adjust video head alignment on, which is the good news. You can find some JVC Service Manuals online, or even on this forum. Even if it's not the exact model, if it has the same screw setup on the A/C head (which I would probably not start with, the video head alignment is more likely) it can tell you about what each screw does. The manual will talk about an alignment tape, which are pretty rare these days, and not absolutely necessary. The video head alignment is pretty universal. Finding the right tool to adjust the posts by the video drum may be an issue there though. If you don't have a screwdriver with a notch cut out of the center or an actual VCR drum alignment tool (basically same thing), if you are careful you may be able to just rotate it with a tiny screwdriver in one of the four notches on top of the post, going very slowly and gently. Alignment can be done with an oscilloscope for most certain results. Youtubers have some DIY videos on this topic of vcr alignment. 12voltvids is one channel that is at least from someone who was in the business for most of his career. Others may be less experienced. But this requires hooking up a scope to test points. I think the test points may be pretty easy to find on a JVC compared to others manufacturers, but still may be beyond your comfort zone, which is fine.
However, many say you can do it good enough without any electrical probing. You need to use a tape that is known to have good alignment to begin with, i.e. A VHS released by a major studio in SP mode. Start by aligning picture and HiFi sound so that it's optimal on SP tapes. Read lordsmurf's guide. But I think the left post adjusts the top of the picture and the right post adjusts the bottom of the picture. And adjusting one does effect the other, so it may require a bit of back and forth. Most important is to take a picture or remember where you started and don't go too far from that point without seeing improvement. Then, try to find an EP tape that was released by a major studio. I happened to have a TV series release from a major studio that had to compress a whole season onto 3 tapes. That may be a good bet for where to find such a tape. The EP tape will have a much narrower tolerance than the SP, so that's why you start with SP. EP may be helpful for fine tuning after optimized for SP. The more tapes you have on hand the better. Not sure if they are necessarily all so well aligned. But they should be trusted over homemade tapes from a random uncalibrated VCR.
Best of luck to you!
The following users thank keaton for this useful post: benzio (04-01-2020), msgohan (04-04-2020)
04-01-2020, 07:22 AM
Thanks... Unfortunately I didn't have luck.
I adjusted the guides a year ago using the LordSmurf's tutorial and everything went well.
Unfortunately this time I was not that lucky: instead of adjust the alignment I worsened the situation and now many tapes don't play at all and after 4 hours trying to adjust and refine the alignment I gave up.
The evolution of the problem is that, after my intervention, some tapes don't play at all because the tape doesn't flow in the path. It start playing very slow, as if the vcr has difficulty in dragging the tape, and after a while the vcr give up and stops.
If I press firmly on the pinch roller toward the capstan the normal speed seems to came back. But It's strange. The pinch roller is quite new and in good shape.
The fact that very few tapes still play well makes me hope that the problem is not too unsolvable but I have to find a reliable repair service here in italy. Not so simple.
04-01-2020, 07:41 PM
Sorry you are having such trouble.
Tape path alignment shouldn't have an effect on the speed of tape travel (horizontal). Alignment of tape path should only effect where it is positioned vertically on the guides.
What you describe about speed sure sounds like something much more mechanical like a motor, a gear, or a belt. Which would require more experience or someone with that experience. There's a long history of threads in the Hardware repair section of the forum. However, it's mostly for those that have some experience in electrical and/or mechanical things and are the types that can service such things. Obviously, this pandemic makes it the worst time to have to rely on anyone else for services. And I cannot say if you'd be better off trying to find another unit or if there's hope in repairing that one. Cost of shipping/repairs can likely compare to the price of another. However, finding a reputable dealer of another unit could also be a roll of the dice. Sorry, I don't mean to be so negative. I only mean to express that caution is important in this market. Right now, it may mean having to wait things out until the world stabilizes to whatever the new norm will be.
04-01-2020, 08:15 PM
You are right. It's too bad that happened in these times. I was (I still) "taking profit" by this forced quarantine dedicating time to my personal digitization project.
Problems using the JVC HR-S9600 S-VHS VCR? MrMaki Restore, Filter, Improve Quality 5 12-01-2019 10:19 AM
JVC HM-DR10000 (PAL) or JVC HR-S9600 (PAL) for S-VHS & VHS transfer? D.Page Capture, Record, Transfer 22 04-04-2019 06:21 PM
JVC HR-S9600 TBC settings modes? Olivier Talouarn Capture, Record, Transfer 50 12-14-2018 01:40 PM
JVC HR-DVS1 or JVC HR-S9600 for VHS restoration? Colota Restore, Filter, Improve Quality 1 04-01-2018 09:32 PM
Suitable price for HR-S9600 JVC S-VHS VCR ? Tomas84 Restore, Filter, Improve Quality 4 10-23-2012 09:02 AM
