06-19-2020, 11:32 PM
Hello all, I'm chugging through my VHS tapes. I have recently read about 16-235 blacks and whites and using the Histogram. Try as I might, it seems that my capture card (pic of details attached) doesn't have a proc amp. I must admit I still don't fully understand what a proc amp is but assume it's a "processing amplifier" for use during capture by adjusting the various options.
The problem I have is VDub reports "No level controls are available with this capture driver", so I can't use the Histogram to adjust the Brightness and the Contrast.
I have got the levels working (Proc amp available) with my VBG-100, but it comes and goes in VDub; sometimes it "disappears".
I can't find any newer drivers for my card.
My question is: is there something I've missed with Vdub and proc amps or is the (availability of the) proc amp solely the responsibility of the card's driver?
Or is there a third-party way of getting the proc amp functionality (basically it seems I need brightness and contrast)? I have read about Graphedit but my head started spinning.
I'm on the latest Windows 10.
Thanks, Al
06-20-2020, 05:07 PM
Totally normal on windows 10(8,7). The only one that would work, assuming the drivers were well designed is XP.
proc amp are tipically: hue, saturation, contrast, luma.
You can do that with vdub filters though at the capture stage (levels filter, hue etc..) the thing is it may introduce a A/V desync.You'll have to try and see what happen
The following users thank themaster1 for this useful post: Hushpower (06-20-2020)
06-20-2020, 09:26 PM
Thanks Master. I will try to set up a XP virtual machine thingee and give that a go.
06-23-2020, 07:31 AM
You cannot capture video (from capture card hardware) in VMs. Direct hardware connections are required, not abstractions layers (ie VMs).
This is why dedicated capture systems are ideal, not using your general-use home computer. However, it's easy and cheap(ish) to build a dedicated system, as anything from the past decade is often fine. (For some of the best capture hardware, like ATI AIW AGP, you need specifics like XP and AGP slots.)
Elite BVP4 video proc amp vs. VirtualDub color correction? filmnoobies Restore, Filter, Improve Quality 3 05-20-2018 10:32 AM
Proc amp filter adjustments, ATI capture card? metaleonid Restore, Filter, Improve Quality 37 04-16-2017 04:07 PM
ATI 600 USB card works in VirtualDub? AGC issues like 650 card? metaleonid Capture, Record, Transfer 13 08-25-2013 08:37 PM
Best VCR? Is a separate TBC or proc amp necessary? Capture card suggestions? lordsmurf Project Planning, Workflows 24 05-24-2011 07:39 PM
