06-29-2020, 10:38 AM
I converted 18 tapes a while ago successfully. I found a 19th and am having problems. The setup is as follows:- Sony Hi8 camcorder to Kworld USB2 converter to Win 7 PC VLC Media Player. Connections IN to Kworld:- Svideo, Red/ White audio.
Connections OUT of Kworld:- USB to PC.
I've set up “Convert/Save” in VLC with the settings I can remember and select the input as WDM 2860 Capture as the Video Device name.
When I start the tape running, I get no on screen preview. I've checked the camcorder by connecting it via “Composite” cables to my TV so I know the camcorder is outputting ok.
A named output (MP4) file is created but it's empty.
I've also tried with Openshot and Bandicam but still no preview.
I suspect either the settings in VLC are wrong or there's a problem with the USB link although it works fine with other functions.
I know it's a big ask but any help would be much appreciated.
06-29-2020, 11:28 AM
That can't look good.
Kworld USB has tiny chance to be ATI 600 USB clone, but I've never seen one. Like Elgato and others, zero model, just brand name, mostly bad cards. Kworld makes nothing, pure rebadger, so unknown what's there. Make be cheap low-quality "grabber" or Easycap/EZcap (aka Easycrap).
Capturing to MP4? In VLC? Yikes. What a mess.
VirtualDub, VirtualDub, VirtualDub -- and v1.9.x, not 1.10.x or the "2' fork.
Lossless codec, preferably Huffyuv (less likely to drop frames).
Capturing video is about quality hardware first, and quality ingest/capture software second. You lack both. That camera is (probably, maybe?) fine -- but no TBC, likely crappy capture card, and definitely wrong capture software. VLC is a player, the end, the capture tools are rudimentary.
The fix, right away, is the correct software for capturing. That's 1st thing to change.
2nd is maybe a better capture card.
3rd is likely a TBC, or at very minimum and minimalist TBC(ish) setup.
06-29-2020, 11:51 AM
Thank you for the quick reply.
What is TBC ?
I'll have a look at VirtualDub.
Thing is, this setup worked fine a couple of months ago.
Thanks again.
06-29-2020, 12:25 PM
TBC is time base corrector, It corrects timing for video scan lines this is inside the camcorder if equipped and corrects frame timing this is usually a stand alone box used as a pass through in the workflow.
"Worked fine" is a loose term, it depends what you are looking for it may "look yikes" to another person who knows what to look for.
06-29-2020, 01:03 PM
Attach a sample clip of a past capture.
06-29-2020, 02:02 PM
TBC. I'm familiar with the term.
"Works fine" Satisfactory for my requitrements. I'm 77 years old and want to preserve my amateur movies from the 90's in a form that doesn't require hooking up a camera in order to view or share.
The smallest clip I have is 155Mb. Is that too big ? If so I'll have to edit something down.
Thanks again by the way.
06-30-2020, 08:30 AM
Update:-
I didn't know if I needed the "audio out" of the Kworld connected to the "line in" of my PC. I'd (probably wrongly) assumed the audio was carried vis the USB connection. I now get audio from the tape but still no video. I've tried two different USB ports on the PC.
Virtualdub:- I downlaoded and installed Ver: 1.9 When I tried to run it, twice, I got the "Blue screen of death" so I've uninstalled it.
07-24-2020, 09:13 AM
Update:- I have replaced the Kworld converter with another Chinese job. It has no separate audio out lead so that addresses my previous point about whether I needed to have it connected. I'm still having problems with the new one. An output file is created but although "Properties" says it has content, there is no video or audio in the output file when played back with VLC. Either the replacement converter is duff or I'm not using the right settings in VLC. I've found instructions on the web but they refer to Linux (I'm Win 7). It would be really helpful if someone was prepared to take me through the setup steps in detail.
07-24-2020, 09:55 AM
It's hard to guide someone without knowing what's going on in their computer, Post screen shots of your setup screens, what's displayed on there, Is your device listed there? Is the right connection selected (Composite vs S-Video), Is the right standard selected (PAL vs NTSC) ... etc.
07-24-2020, 10:29 AM
Thank you very much. I'll prepare some information and send it soon.
07-24-2020, 12:22 PM
Can't access your files, they are not public, use forum picture upload feature.
07-24-2020, 01:11 PM
I think I've now uploaded them.
07-24-2020, 03:02 PM
I've tried sharing them with you.
07-24-2020, 05:06 PM
Requires google sign on, I don't use google sorry.
07-24-2020, 09:24 PM
I got the links sent to my e-mail but those pictures show only conversion settings, Where is the capture card settings, that's where your problem is, conversion comes after you have a working video from the capture card.
07-25-2020, 07:06 AM
Thank you for your continued patience.
The first pic I sent (VLC 1) shows the selecting the capture device.
Having done that, the only option is to select one of the items from the "Play" drop down.
I don't know what "Enqueue" means. If I select either "Play" or "Stream" nothing appears on the screen when I start the tape playing. If I select "Convert", an MP4 file is created which doesn't display video or audio on playback.
I hope you can see the screen shot VLC 5 this time.
07-25-2020, 08:30 AM
What's in Advanced options?
Anyway the way I look at it VLC doesn't seem to have the option to select S-Video, so you have a driver problem, Look for "Crossbar thingy" in this forum.
07-25-2020, 10:48 AM
I looked up Crossbar thingy and most of the posts refer to the Pinnacle kit abd Vdub. My capture card isn't a Pinnacle (Dazzle ?). I've also tried Vdub at your suggestion and abandoned it as it crashed my PC. I might try it again though.
I've attached two screenies of "Advanced Options".
When it was working previously, I only selected 25fps and PAL-D
The S-Video out of the camera in connected to the S-Video of the capture card. The only input to the PC is USB.
07-25-2020, 03:33 PM
Crossbar thingy has nothing to do with Pinnacle, You should try it before you judge it.
