10-06-2020, 02:47 PM
Kingliar Kingliar is offline
Hi,
I’ll try to describe my issue :
Panasonic nv-fs200 —> s-video out —> Advc110 s-video in —> fcpx on a Mac Mini
- tape plays fine. Tried it on tv with 3 different vcr’s...Damn that looked awful
- video in fcpx looks ok. Noise/grainy but that’s to be expected I think.
Now, every 2-3 sec the video “stutters” in fcpx creating new video fragments. (Maybe it dropping frames? But it’s so regularly). Tbc turned on is making it actualiteit worse.
I also have the Elgato video capture. No stutter there.
Alle files are stored on an external thunderbolt 3 harddrive.
Anyone else experienced something like this? And maybe found a solution?
10-06-2020, 04:06 PM
VCR good.
ADVC not great, color loss, 4:2:0 PAL. Acceptable.
Elgato earned named "Elcrapo". Don't use.
Grain and noise made worse by ADVC. Gets blocky, too.
Panasonic VCRs too sharp by default. Grain, noise, halos. Slider less sharp.
NLEs like FCP do poor job of capturing.
"Stuttering" too vague. Sample clip needed.
10-06-2020, 05:13 PM
VCR good.
Thanks for your quick reply.
Here are two clips :
I used the Elgato to maybe rule out the hard drive.
What capturing software for Mac is recommended ?
Sample clip FCPX : export file from, well, FCPX. "Stutter" Maybe not well notacible
Sample clip monitor : What I'm watching on the screen. Every 2-3 seconds the image stops very briefly and starts again.
Hopefully it good enough, if not, I'll try to get better examples tomorrow.
10-06-2020, 05:43 PM
I see dropped frames
Panasonic has field TBC (multi-line TBC).
- Line/field TBC cleans the image.
- Frame TBC cleans the signal.
- You need both.
Frame TBC prevents dropped frames. Line/field does not. Signal issues cause dropped frames.
NLEs, again, really bad at capture. Many actually cause dropped frames.
HDD rarely issue. Nor RAM. Issue usually CPU. Per-core speed matters, saturation of data in the core.
Standard "lack of TBC" issue.
BTW, not just any TBC will work, you need non-flawed frame TBC made for consumer sources.
What is current hardware in use? NS-FS200 + ... ? Just VCR and ADVC card? If so, not good. This is what you should expect with just that pair of items.
10-07-2020, 01:09 AM
Thanks,
I'm using only NF-FS200 + ADVC at this point.
What is recommended software for capturing?
With the "Elcrapo" there don't seem to be issues with frame dropping (I'm not going to use it). Is it probably the advc110 or FCPX (in combination with frame TBC) ...because if it's only the absence a a frame TBC, should I expect similar issues with the "Elcrapo" ?
I’m trying to understand why the advc110 and/or fcpx would be dropping frames...and the Elgato with it’s software seemingly doesn’t. Anyone?
10-08-2020, 03:52 PM
1 - ADVC likes to drop frames more.
2 - NLEs are lousy at video capture, too much overhead.
advc 110, advc110, stutter
QTGMC creating stutter on timecode breaks? stb2000 Restore, Filter, Improve Quality 8 01-21-2019 05:27 PM
For Sale: Canopus ADVC110 MrTIM Marketplace 0 05-01-2018 09:01 AM
Stutter with too much movement, convert Hi8 in VirtualDub? KoenDG Capture, Record, Transfer 1 12-13-2017 09:55 AM
Video stutter problem from VHS tape? SinghDk Capture, Record, Transfer 7 01-26-2017 12:32 PM
Inferior capture because I used Sony Vegas with Canopus ADVC110 DV box? lordsmurf Capture, Record, Transfer 0 09-28-2010 08:06 PM
