02-22-2021, 04:18 PM
dziey3 dziey3 is offline
I've been getting these weird artifacts that show up every now and then on some of the tapes I've recorded. I haven't found anything like this on artifact atlas, but you'll see it looks pretty bad on these yellow shirts.
Example
The artifacts do not show on my camcorder's flip out screen, so I'm pretty sure it might be an issue with my capture device, but wanted to see if this isn't a known analog artifact that I'm unaware of.
Any idea what could be causing this?
02-23-2021, 10:51 AM
traal traal is offline
What capture card are you using? It looks like the yellow is somehow overloading it. If you're using VirtualDub, you'll want to check the histogram and adjust brightness and contrast before capture.
02-24-2021, 01:16 PM
Sony camera > RCA to HDMI converter/upscaler > Flint 4KP Plus capture card > OBS recording mp4
It seems to pop up intermittently and is completely random from what I can tell.
02-24-2021, 01:52 PM
Do not use OBS. That is streaming recording software, not for analog capture.
You're making your videos look bad by using it.
That RCA>HDMI converter method is junk, and will not work. What you see is what you get with it.
Strange Color Bars appearing in 8mm Transfer deadbeatdad Restore, Filter, Improve Quality 2 07-30-2020 04:22 PM
Color Correcting and Removing Artifacts from 8mm Film Scan ehbowen Restore, Filter, Improve Quality 17 06-05-2018 03:49 AM
Color band artifacts during capture benzio Capture, Record, Transfer 3 04-04-2018 12:06 PM
Strange problems capturing from SR-V101 with PVR-250 Bilge Capture, Record, Transfer 29 01-31-2012 09:58 PM
Artifacts in video when capturing DV with Scenalyzer gilou8 Capture, Record, Transfer 1 12-28-2011 08:22 AM
