04-15-2021, 12:17 AM
cuci cuci is online now
Hi !
Just a simple question..
Are build in TBC in portable s-vhs-c cams are good as VCR's TBC ?
I need to archive some s-vhs-c cassettes , but the adapter cassettes are rare and expensive and i preffer to bye a cam instead adapter.
Some models i found in BG /Bulgarian/ marketplace :
Panasonic NV-SX50
JVC GR-SXM58
JVC GR-FX220A
Assuming the cameras are technically ok, which is preferable?
Camera with built-in TBC or recorder with built-in TBC ?
Thanks in advance !
04-15-2021, 02:25 AM
Some high end S-VHS camcorders did very well but the major difference between a VCR and a camcorder is the tape wrap angle, The VCR scans the tape in 180° wrap with two heads, one field per head, While the VHS-C camcorder scans the tape in 270° wrap and uses a small 4 heads drum rotating at higher than normal speed to track down the 2 fields, this is not ideal especially for LP tapes recorded on a different camcorder, SP recordings are more resilient. This is why a full size drum VCR is recommended.
04-15-2021, 03:30 AM
Understood.
So, cassette adapter is preferred.
Thanks!
..because i dont know these cams are hi-end , or not..
Thanks again !
04-16-2021, 09:29 PM
S-VHS-C cameras did a terrible job of playing tapes.
Been there, done that.
Learn from my mistakes, don't repeat them. S-VHS-C cameras like to eat the -C tapes.
Use two TBCs, or only one? jose carlosv Restore, Filter, Improve Quality 14 03-16-2021 04:40 PM
Digitising Video8 Hi8: original camcorder or Digital8 camcorder? sverice42 Capture, Record, Transfer 7 08-05-2019 10:08 AM
Anyone knows if these VCRs are good for video transfer? Asesinato Capture, Record, Transfer 1 04-13-2012 08:09 AM
