08-26-2021, 03:49 PM
BigMae1 BigMae1 is offline
Hello. I am currently struggling on what to do in terms of my capture setup. The audio is out of sync with the video and I'm pretty sure my recording setup is all wrong. I am looking to maybe redo the entire setup or change what is needed.
There is also some discoloration at the top of basically every 8mm tape. Like a red bar at the top.
What I'm trying to do is capture / record both VHS and 8mm (Sony Handycam) tapes.
Setup:
HonestTech VIDBOX VHS to DVD
Panasonic PV-8661 VCR (stereo)
Sony Handycam CCD TR-614
PC:
Xeon X3470 (4 core 8 thread) should be fast enough?
8GB RAM
GTX 550 TI
Running Windows 10
Process:
Recording straight from the VIDBOX device straight to VirtualDub
Copying to my main (much faster PC) over a network share to deinterlace using Yadif and Virtualdub
Then compressing with HandBrake to MP4 so the file is a normal size (still maintaining 60FPS after Yadif deinterlace)
Any advice would be helpful! Thank you!
VHS/8mm capture setup VirtualDub delayed audio? BigMae1 Capture, Record, Transfer 6 08-27-2021 03:24 AM
Video is consistently delayed 170ms after audio in VirtualDub2? Unicron129 Capture, Record, Transfer 3 12-29-2020 10:15 AM
Capture setup; use VirtualDub 64, filters? Amanjm Capture, Record, Transfer 6 02-22-2018 12:09 AM
VirtualDub doesn't capture audio? boobounder Capture, Record, Transfer 6 07-26-2014 11:59 PM
