09-19-2021, 06:49 AM
Delta Delta is offline
Here is my set up
Source tapes: Hi8 recorded by Sony TRV95E Hi8 XR PAL camcorder played back on Sony TRV461E D8 Handycam.
Capture Card: 710-USB
System: Win7 SP1 32-bit, VirtualDub 1.9.11, Lagarith/YUY2, audio capture to uncompressed PCM
Sony TRV461E D8 Handycam:
TBC: ON. I guess it helps; should i leave this ON? I do not have an external TBC.
DNR: OFF. Color noise reduction post capture
Crossbar Thing:
Video Extensions tab: Does startup mode impact capture? I guess not.
Video Decoder tab: Should "VCR Input" be checked or unchecked?
VirtualDub Settings
I have arrived at the following setting based on my understanding from the detailed VirtualDub guide by sanlyn - http://www.digitalfaq.com/forum/vide...-settings.html Pinnalce_Video Decoder.jpg
Drop frames when captured frames are too close together: Unchecked. Will VirtualDub report dropped frames if unchecked?
Insert null frames when captured frames are too far apart: Selected/Checked, since I do not have an external frame TBC. Do null frames help to keep A/V going out of sync?
Sync audio to video by resampling the audio to a faster or slower rate: Checked
Correct video timing rate got fewer frame drops/inserts: Unchecked for for integrated A/V cards
Automatically disable resync when integrated audio/video capture is detected: Checked - as suggested for integrated A/V cards
Direct Show Options: Check "force audio clock" entry
Could you please comment on these settings and if I can proceed to capture with these? Thanks
The following users thank Delta for this useful post: gundy (11-08-2024)
09-19-2021, 07:50 AM
Yes, line TBC on.
That's not Crossbar Thing. That's the Pinnacle driver dialog.
Most is left at default.
"VCR input" does nothing.
VirtualDub, top setting wrong, you want to drop here.
This card has internal sync, so do not resync. Auto checked is correct.
Don't force audio clock.
The following users thank lordsmurf for this useful post: gundy (11-08-2024)
09-19-2021, 09:31 AM
Thanks for the quick reply LS. I have attached the revised settings to confirm my understanding.
I have also corrected the title of the thread.
Update: The corrected title is not being reflected - I guess I may have to edit the title elsewhere
710-usb, hi8 capture, virtualdub capture
Recommendations for JVC VCR playback settings? stymie Capture, Record, Transfer 9 10-12-2020 06:05 PM
Settings for capturing via hdmi and capture card-virtualdub wigam Capture, Record, Transfer 1 02-16-2018 04:45 PM
VCR and VirtualDub VHS capture settings and advice sanCapture Capture, Record, Transfer 2 01-26-2014 05:28 PM
HuffyUV Settings with VirtualDub for capture naripeddi Capture, Record, Transfer 7 04-12-2013 02:50 AM
