07-14-2022, 09:48 PM
mlsnag mlsnag is offline
I bought a Pinnacle card and I installed the drivers and downloaded the Crossbar Thing.
The preview video has lags. The captured video though seems ok, no lags.
Also, now I have a lot of "not responding" issues with Virtualdub when I'm trying to change something in settings or whaterver. I dont unterstand why :/
Even when I restart my pc it doesn't turn on again (or turn off If I shut it down). I've to use the button to turn it off. If the "not responding" issue starts I can only restart my pc to make it work again.
Any ideas? What causes that?
thanks!
07-14-2022, 10:33 PM
To start, what OS?
07-14-2022, 10:40 PM
Win7
I also installed Net framework 4 cause I couldn't open Crossbar Thing.
Is there another way to make Pinnacle work without Crossbar Thing? I want to see If Crossbar Thing is the problem. Because If Crossbar isn't the problem here, I'm assuming it's the Pinnacle.
07-16-2022, 10:11 PM
For the moment, try using composite, not s-video.
Is DirectX disabled in VirtualDub main settings?
07-16-2022, 10:58 PM
I can't choose Video source ("No video sources"). So, I only see black preview (composite). Even though I open crossbar, still black. I can only see preview with s-video+crossbar (with lag).
This one?
08-01-2022, 01:54 PM
Any help? I still have the same issue.
Should I install different drivers?
Should I try Virtualdub 2?
VirtualDub capture not recording? JAJT Capture, Record, Transfer 12 06-27-2024 12:20 AM
VHS audio issues when using VirtualDub? MechVHS Capture, Record, Transfer 15 08-23-2018 04:45 AM
VirtualDub audio sync issues? rds11 Capture, Record, Transfer 2 09-20-2014 01:48 PM
Timming issues with ATI 600 USB in Win7 with VirtualDub? JasonCA Capture, Record, Transfer 8 04-08-2013 07:08 PM
