05-23-2024, 04:34 PM
Fabi75 Fabi75 is offline
Hello
I intend to digitalize the VHS video collection of my family. I have the following equipment:
- Panasonic NV-HS1000 SVHS-Videorecorder
- Hauppauge USB-Live-2
- PC with Windows 10 Home 64bit
I use VirtualDub 1.9.11 and VirtualDub 2. I was told I should use VirtualDub 1.9.11 for capturing.
What is the best codec for the losless capture of VHS videos (PAL)? I was told that the Blackmagic SD 8bit 4:2:2 codec is the best. Unfortunately I cannot use this codec either in Vdub 1.9.11 or in Vdub 2. In Vdub 1.9.11 I don't even see that codec and in Vdub 2 I get error messages when I use that codec. Only Blackmagic 8bit MJPEG codec works for me.
Thank you in advance for your help, Fabian
05-24-2024, 02:59 PM
KhAoS182 KhAoS182 is offline
Originally Posted by Fabi75 View Post
Hello
HuffYUV or Lagarith
Wrapper vs. Codec J2fusion Capture, Record, Transfer 1 03-28-2021 12:56 PM
VHS capture codec in VirtualDub? Avagadro1 General Discussion 3 02-28-2021 07:22 PM
Aja Kona Lhi best codec waloshin Capture, Record, Transfer 1 01-16-2021 11:49 PM
Gspot Codec Analysis Tool - AVI codec info [DOWNLOAD] admin Encode, Convert for discs 1 03-19-2011 10:49 PM
DVD capture with Vegas, which codec ? Tafflad Capture, Record, Transfer 1 02-04-2010 05:41 PM
