03-10-2023, 06:05 PM
Xhumeka Xhumeka is offline
For my video I just went fullscreen and then started recording... it seems to record at your current resolution (if GPU recording is enabled).
There is an option to "load configuration" and you can create a config file that includes specifying resolution using the instructions here (though I never tested it):
https://docs.libretro.com/guides/rec...-coding-config
03-10-2023, 06:35 PM
Jeelock Jeelock is offline
Oh gotcha, thanks! At least it looks crisper, just looks like there's TOO many pixels now
VirtualDub fps and resolution issue? bzowk Capture, Record, Transfer 3 12-19-2019 06:54 PM
Virtualdub vs TMPEGEnc Resolution/Aspect Ratio Differences MadScientist Capture, Record, Transfer 7 08-07-2019 06:50 PM
Capture resolution choice - 352x480 not in VirtualDub options Mejnour Capture, Record, Transfer 1 09-28-2013 06:52 PM
Testing bitrate/resolution from DVD recorders, for recording TV Giana Videography: Cameras, TVs and Players 4 09-27-2012 04:01 AM
What Resolution ? Nintendo NES Game Play video capture (recording) JLegnon Capture, Record, Transfer 16 10-10-2011 03:16 PM
