03-14-2023, 05:57 PM
slneilryan slneilryan is offline
Hi
I would like to begin using Virtual Dub to capture my video. I downloaded the version from the guide on this website but when I click capture avi I receive the messages attached.
I can open an existing avi file ok but the program crashes when I try to capture.
Suggestions?
03-14-2023, 06:56 PM
What OS?
What exact version of VDub?
What is your choice of compression?
When EXACTLY does the crash occur?
Does your DxDiag reveal anything about the crashes?
03-14-2023, 07:14 PM
S = Windows 7
VDub =1.9.11
What is your choice of compression? I am not sure what you mean?
When EXACTLY does the crash occur? When I click Capture AVI the messages that I attached to the original post pop up. Then when you click anything, Vdub closes.
Does your DxDiag reveal anything about the crashes? Not sure what is DxDiag?
03-14-2023, 07:20 PM
Just read a thread OP JoRodd from Feb 2018 with the exact same problem. The solution that worked for him was using a different version of Huffyuv. Do I need to install this as well before running Vdub to capture avi.
Go easy newbie here.
Thanks in advance.
Santa Cruz installation failure? hogharry Capture, Record, Transfer 4 07-20-2021 07:32 AM
JVC D-VHS failure? thomash85715 Video Hardware Repair 3 12-31-2020 08:45 PM
WDM capture driver failure, ATI MMC 8.8? colony Capture, Record, Transfer 2 01-22-2019 04:19 PM
VirtualDub program failure, crashes on capture? JoRodd Capture, Record, Transfer 9 02-27-2018 12:19 AM
Interesting blank disc failure NJRoadfan Blank Media 5 11-13-2013 11:26 PM
