03-18-2023, 02:08 AM
Gary34 Gary34 is offline
I have a Panasonic 1980 I had completely restored by Tgrantphoto. I have a Dell Inspiron 5675 with a ryzen 7 cpu with eight cores, 3 solid state drives and an old disk drive that came with it. And 34 gigs of ddr4 ram. I have a black magic intensity shuttle. I have used premier pro to digitize some videos. I have a tape rewinder that looks like a car. After seeing this site I am thinking the rewinder is basically just a toy car that I shouldn’t use to rewind my tapes and I need a capture card and a frame tbc also I am going to capture with virtual dub now. Are there and hardware recommendations that you guys could give me. Thanks in advance.
So from what I’m seeing maybe I should go with a data video tbc-1000. I am going to get a dehumidifier too for that room. I have a really nice hepa filter that I bought for myself years ago but we keep it in that room because it’s huge and the baby runs into it with her walker. I was kind of wondering about the data video tbc-1000 because it’s power of from the wall outlet and I’ve heard that power source isn’t as “clean” as from the computer and it can introduce grain into your video. Idk I am weary about hardware choices because I got that black magic intensity pro on the advice of a YouTube video from someone I thought knew what they were talking about and i couldn’t use it with virtual dub. I am also wondering if I should get a broadcast compliant monitor or just a regular as tv. Hopefully lordsmurf gets on here and gives some input. I feel like maybe im losing some of the benefit of having a nice redone Panasonic ag1980 with using a blackmagic intensity pro capture device and no frame tbc. Anyways thanks.
Maybe I should get a Green AV Toolbox AVT-8710. I hear it works good with Panasonics. Idk about the repeaters in the data video 1000 and if that would introduce a bunch of noise.
03-18-2023, 03:10 PM
AG-1980 is a great model of VCR. Unfortunately, as many of us learned the hard way, TGrant refurb work is somewhat shoddy, and doesn't last, needing another costly repair just a few years later. Most of us send to Deter now. But, for the moment, you have a working deck. My advise is to use it now, because I doubt it'll be in that condition longer term.
Computer is fine. Capturing is a 2000s task, and almost anything from 2010s and 2020s is fine, way beyond minimums required.
Be careful with rewinders. Most were "high speed", and tapes are too fragile. Those were almost exclusively made for the nuisance of "be kind, rewind" (aka Blockbuster video). You don't want to put important tapes in these, odds are it will mangle and "eat" them instead.
Yes, frame TBC is requird. You have the line (actually field in the 1980, aka multi-line, aka "infinite window") in that 1980. So halfway there! Line cleans the image, frame cleans the signal, you need both.
DataVideo TBC-1000 has caps concerns now. I've literally not seen a truly working DataVideo 1000 unit in at least 6 months (aside from the units I refurb'd). Several members have bought "working/tested" (BS!) units on eBay, only to need them repaired before using (aka $500+ to the cost). But also note that some DataVideo errors can be irreparable, and you bought a paperweight.
The green AVT-8710 is sadly now another model that you cannot trust to blindly buy, especially not on eBay. This model of TBC has gotten rare, due to failures in the past 15-20 years. The AVT-8710 was the budget model from Cypress, and most essentially lacked adequate cooling, having been housed in a tiny plastic enclosure. The latter black AVT-8710 has catastrophic flaws, and the unit actually creates dropped frames (and many others issues). Yep, it does the opposite of the intention, causing drops instead of preventing! Now then, in the past year, shady eBay sellers have started to swap these "working" black boards into failed green units. This has happened multiple times now. A few buyers found this out too late, and are now stuck with bad units. (There are some odder variants of latter greens, but those are rarer, not worth discussing here, not now.) NOTE! A member here recently bought a "green" (BLACK!) unit, and it may ended relisted soon. BEWARE!
Blackmagic is not a suggested cards, and is especially prone to issues even with line+frame TBCs in use. However, it is based on factors. Some try and try, and it fails and fails. Other try, and it squeaks by (or so is claimed). Blackmagic no longer suggest their cards for consumer analog sources, due to the common issues.
Most Youtubers are newbies themselves, and know as much (or less!) than you do. Always remember that. They're always found out in time, though some try to erase these comments, to keep pumping out their horrid advice. I see this in financials, video, computers, and others. Reddit sometimes calls out these shoddy Youtubers, but then Reddit too often has it's own groupthink issue.
Broadcast monitor is not needed whatsoever. Even I don't bother with that anymore. For starters, those drift over time, and most have drifted far outside useful values by now.
Yes, your instinct is correct here. Good VCR, made worse by poor capture card choice, and not being chased by the frame TBC. It's like buying a high end sports car, one that requires super unleaded for the turbo charged engine, special synthetic oils. Yet you fill it with regular, give it basic 10W30. The output from the car, and the output from the VCR, is ruined.
I'm having a busy week and weekend, catching up on tasks, but I sent you a PM as well.
03-18-2023, 11:27 PM
LS, so what is your recommendation for a frame TBC?
Recommendations for VCR and capture card? mlsnag Capture, Record, Transfer 7 04-26-2022 07:35 PM
Capture card vs. USB? AIW dongle? CPU recommendations? zippydan Capture, Record, Transfer 4 10-21-2021 07:53 AM
Capture hardware recommendations, gear servicing/defects? Qaenos Capture, Record, Transfer 1 01-09-2020 01:30 AM
Video capture card recommendations? wbleigh Capture, Record, Transfer 3 04-14-2017 10:54 PM
S-video capture on Linux via ATI USB card, FFmpeg - recommendations? wronkyn Capture, Record, Transfer 1 11-30-2014 01:45 PM
