05-05-2023, 11:04 PM
aquarius007 aquarius007 is offline
Can I connect my Canon Elura camcorder 2 to my VCR and use it as a passthrough?
05-05-2023, 11:34 PM
Here's the manual:
https://www.manualslib.com/download/...ura-Elura.html
Follow the procedure on page 78 and see if you get anything out of the Firewire port (assuming you are intending to capture from the Firewire).
The following users thank Hushpower for this useful post: aquarius007 (05-06-2023)
05-06-2023, 03:08 AM
It might cram the video to digital, but lowers the quality to compressed DV (blocks, lost color), and likely has no TBC for passthrough. So the signal must be TBC processed in a quality S-VHS VCR, and an actual frame TBC.
The DV camera is just a dumb digitizer box, nothing special, not quality.
The following users thank lordsmurf for this useful post: aquarius007 (05-06-2023)
05-06-2023, 11:04 AM
BW37 BW37 is offline
No, the Elura 2 will not do analog to DV/Firewire passthrough. The 2 was/is my original DV camcorder. The early camcorders like it did not support this feature.
BW
The following users thank BW37 for this useful post: aquarius007 (05-06-2023)
05-06-2023, 08:03 PM
Thank you, I appreciate all of the replies. I used the Elura 2 to transfer miniDVs to my pc. Too bad I can’t use it as a passthrough for my VCR. I have a JVC HR 3600 and very little money to purchase additional equipment. I was given a Dazzle, but the quality of the output is poor. Can you please suggest a better piece of equipment I can purchase (for $100 or less) that I can pair with my VCR?
Any Canon Video 8 / hi8 pal camcorder with tbc ? chrisbati Capture, Record, Transfer 4 10-13-2021 09:29 AM
Capture analog using VirtualDub with camcorder passthrough? rf99 Capture, Record, Transfer 10 04-25-2016 12:40 AM
Camcorder passthrough vs. analog-to-lossless capture? rf99 Capture, Record, Transfer 2 04-07-2016 04:24 AM
