07-02-2023, 10:36 AM
proxyy proxyy is offline
Hi, i’m very new to the world of analog video technology. I have recently gotten into glitch art and perform with a band doing visuals for them. I have been forced to bring my crt tv to every show and rescan that with a camera and send that to a projector. I need a TBC very badly but I don’t want to spend $300 on a hotronic one off ebay if it won’t work with particularly glitchy signals. Anywhere i’m just looked for some recommendations and any information that could be helpful
07-02-2023, 11:02 AM
Don't waste time buying junk TBCs off eBay. That's not what you want. There are some very specific models, and specific versions of those models, that you want for this.
What is your realistic budget here? (Not a mere $300, way too low to get a non-junk TBC.)
That will determine the exact unit.
For other readers, glitch/video art is not the same as standard video conversion needs (ie, VHS to digital conversions). It needs to respect the errors, not really correct (ie, remove the glitches, the art), nor make worse. There is some overlap with budget great used for conversion.
07-02-2023, 11:40 AM
Honestly my budget can’t be too crazy high but honestly at this point i’m willing to pay whatever just to get my setup working. As long as it’s reasonable i guess haha
tbc, time base corrector
Unsure how to digitize 8mm tape using Panasonic DMR-EX98V klajdi2123 Videography: Cameras, TVs and Players 2 03-28-2023 08:19 PM
Best capture card for glitch effects? (bad signals) OldZisty Capture, Record, Transfer 8 09-03-2022 02:09 AM
What is this Hi8 glitch? PAL Hi8 tape in NTSC camcorder? broadcastronauts Capture, Record, Transfer 16 03-28-2021 11:22 AM
Weird VHS tape glitch: what is it, can I fix it? [SOLVED] holocron Capture, Record, Transfer 22 12-13-2017 09:42 AM
Video glitch causing playback issues manthing Edit Video, Audio 3 11-13-2014 02:08 PM
