11-16-2023, 03:32 PM
Kiriakos Kiriakos is offline
Greetings from Greece,
What is the difference between the JVC HR-S7960E and HR-S8690E?
Do you know which is better?
I am converting some old anime VHS tapes to DVD, and I like to know if I can get better quality.
My current setup is:
JVC HR-S7600EU & Panasonic NV-FS200.
JVC DR-M100SE DVD recorder.
Will I obtain better quality if I upgrade to the JVC HR-S7960E or HR-S8690E?
What about the JVC HR-S9765EK & HR-S8965EK, are same as the JVC HR-S7960E & HR-S8690E?
Thank you.
11-16-2023, 04:39 PM
KhAoS182 KhAoS182 is offline
I don't like Dynamic Drum VCR'S, I will fo for 7600, 7611 or 7722, I have all these and I love them.
11-24-2023, 03:27 PM
johnEtna johnEtna is offline
Which one would you choose between these three? I'd like to know more about 7600 vs 7611. Which one do you recommend?
I know the 7611 have no s-video output, but scart output. Do they have the same tbc abilities?
Thank you!
01-03-2024, 07:54 AM
7600, 7611, 7711, and 7722 are all close to identical.
The JVC HR-S7611 has s-video.
But it appears there may be two versions (?), or more likely a mislabeled unit being sold as 7611.
01-03-2024, 08:22 AM
Thank you!
I suppose you are referring to a certain ebay post. Yes, I've noticed it a long time ago, and you're right. It is a S5970 mislabeled as a S7611.
JVC VCR EK, EG, and E differences? FrodoGuy85 General Discussion 2 04-02-2023 05:19 AM
AIW AGP WinXP vs. ATI 600 or VC500 OS X differences? thefrog1394 Capture, Record, Transfer 20 01-24-2021 04:20 PM
TBC differences on DVHS decks? AndyO6322 Capture, Record, Transfer 3 04-22-2013 12:14 AM
BVP-4 vs. BVP-4 Plus major differences? Tuco Restore, Filter, Improve Quality 14 05-23-2011 08:27 PM
