12-23-2023, 09:12 AM
HomeVideoProject HomeVideoProject is offline
Hi all, I'm just getting started with a project of transferring ~300 analog tapes and purchased a premium workflow from LS.
As part of this, I'm starting to experiment to dial in my config before starting to taking on the bulk of the work.
Problem: VirtualDub using HuffYUV Compression is outputting my video in RGB instead of YUV 4:2:2.
Steps to reproduce:
  1. I captured a video using uncompressed AVI
  2. I used VirtualDub to crop the video
  3. I set the Video > Compression to Huffyuv v2.1.1
  4. File > Save as AVI...
Media Info for uncompressed file:
Media Info for HuffyYUV file:
Config of Huffyuv:
Thanks in advance!
12-23-2023, 09:39 AM
Test with Lagarith, what does it report?
Confirm VirtualDub version in use.
VirtualDub not recognising Huffyuv codec? Deadsy Capture, Record, Transfer 10 01-27-2024 01:59 PM
Setting up VirtualDub with Huffyuv? NotsafeforNick Capture, Record, Transfer 4 08-02-2022 07:59 AM
HuffyUV not showing up in VirtualDub? zackhammerle Capture, Record, Transfer 3 09-09-2020 02:02 PM
HuffYUV Not Installing in XP w/VirtualDub colony Encode, Convert for discs 9 05-01-2019 05:19 PM
ATI MMC vs. VirtualDub, Huffyuv? Pinnacle vs ATI? SinghDk Capture, Record, Transfer 11 05-02-2015 04:07 AM
