02-09-2024, 08:31 AM
Apothocary Apothocary is offline
First, here's my setup:
PAL VHS (VHS-C in adapter) > Panasonic NV-FS100 VCR > VCAP800 Capture Card (s-video) >VirtualDub1.9.11 (Windows 10)
I have read the VirtualDub Settings Guide and got it all dialed in (all settings, no audio playback checked etc). I am also using the Lagarith Codec.
I do not have a TBC in my workflow.
I am encountering a "repeated frame stutter", however. These could be inserted frames, I'm not sure. I have tested the videos directly into my TV and there's no issue.
This issue isn't specific to VirtualDub, just so that's known. This stutter is evident in ArcSoft as well. My inkling is it's the VCAP800, but I'll let you guys be the judge there.
Here is a video to explain things better. Sorry it's animation, it's my only cassette that isn't a personal home video!
Repeated Frame Stutter
Thanks in advance!
02-09-2024, 02:45 PM
Welcome.
- You lack frame TBC.
- VCAP800 is a low-quality "grabber", not suggested for multiple reasons. £30 on Amazon/eBay is a ridiculous low price for a capture card, like paying £0.25 (25p) for a loaf of bread. How fresh/good would you expect a 25p loaf of bread to be?
This is what happens without frame TBC, when using non-quality capture cards.
The fix = getting a quality frame TBC, or frame TBC(ish) + quality capture card.
02-09-2024, 02:53 PM
Thank you for confirming my suspicions.
Would the following be a good fix, then:
Panasonic DMR-ES10 + Pinnacle USB (I have WIN10, as previously mentioned)
If so, I may purchase the PAL Pinnacle from you.
Not sure what Pinnacle this is but could it be a decent one? I’m happy to roll the dice, if so.
02-09-2024, 05:39 PM
The ES10 is a DVD recorder, not a TBC.
It has the unique feature of a strong+crippled line TBC for passthrough, with a non-TBC frame sync. It reduces quality. It's actually worse for PAL users than NTSC users, as it messes with exposure/brightness/luma. The ideal use is for achieving net quality gains, such as using it for anti-tearing.
And yet, better than nothing at all. Not ideal, but rather least-worst option. Worst is nothing.
There are better options, at multiple price points, from about $600 range to obvious $2-3k range for the actual/best/ideal TBCs. But it also depends on VCR, sources, etc. A conversation must always be had when you want to jump down the budget gear rabbit hole.
No.
Don't random buy items.
- If you're a video, that's one thing.
- But if you want to buy this gear in order to use it, then don't random buy items. You're just wasting time, energy, money. I never understand this way of thinking. ABC may be cheap, but you need XYZ instead.
02-09-2024, 05:44 PM
Well, this is all new to me so that’s why I’m asking. To clarify, is this particular unit definitely not compatible for my uses? Thank you.
02-09-2024, 05:51 PM
Yep, I get that.
That unit is not a suggested model. It's much older hardware from the late 90s into early 00s. That's why those are generally so cheap.
02-10-2024, 06:05 AM
Thank you, LS. This is all good to know.
For thread posterity, we have moved to PM for the potential sale of a capture card.
ATI TV Wonder USB 2.0 video stutter? dudemcgraw Capture, Record, Transfer 2 07-05-2021 12:21 PM
VHS capture with ADVC110 video stutter? Kingliar Capture, Record, Transfer 5 10-08-2020 03:52 PM
QTGMC creating stutter on timecode breaks? stb2000 Restore, Filter, Improve Quality 8 01-21-2019 05:27 PM
Stutter with too much movement, convert Hi8 in VirtualDub? KoenDG Capture, Record, Transfer 1 12-13-2017 09:55 AM
Video stutter problem from VHS tape? SinghDk Capture, Record, Transfer 7 01-26-2017 12:32 PM
