  #61
04-03-2024, 09:35 AM
Thermaltake Thermaltake is offline
Originally Posted by BW37 View Post
There's a very long thread over at VH about using the Panny DVD recorders for passthrough. In PAL world there are many more models that are said to work for this purpose (vs. NTSC) so you should be able to find something.
BW
Thanks.
I am in PAL region. I just can't decide what model of player should I get to get best picture like ES10/15 had with passtrough, because ES10 and ES15 are nowhere to be found.
Found ES10 here locally in my coutry for cheap, and bought it. Can't wait to test it. But without remote unfortunately.
04-04-2024, 07:43 AM
Remote is required to access menus, and you must alter settings from default.
04-04-2024, 07:55 AM
Well, I will buy it from ebay or somewhere...
04-04-2024, 08:15 AM
Get a unit with battery cover, images showing it to be clean, no leaked battery acid. eBay is a terrible place for most gear, but the remotes can be fine.
The following users thank lordsmurf for this useful post: Thermaltake (04-04-2024)
  #65
04-04-2024, 08:35 AM
I know, thanks for warning.
His original remote is EUR7720KM0, right ?
JVC S-VHS not in buying guide? theseeker General Discussion 2 02-23-2023 08:55 AM
Buying a VCR in 2021 drfsupercenter Capture, Record, Transfer 0 12-27-2021 11:04 PM
Digitalizing Video8/Hi8 to Mac? kwiN Capture, Record, Transfer 5 01-22-2020 03:10 PM
Digitalizing VHS tapes using NRS50 Snell & Wilcox? JMA92410 Capture, Record, Transfer 2 09-15-2018 06:13 AM
Digitalizing VHS tapes, what should I buy? F3LixBl0m General Discussion 1 05-21-2018 07:15 AM
