03-13-2024, 07:17 AM
badonica badonica is offline
Hi,
I’m trying to capture video using Virual Dub ( 1.9.11) ( Compression: Huffyuv v2.1.1) but experiencing the audio warping and dropped frames?
I’ve tried using the Canopus MPeg Pro Emr to capture MPEG2 files and had no problem for a 2.5 hour capture
with the audio?
My workflow is as follows:
JVC HR-DVS1
TBC 1000
ATI USB 600
Windows XP Pro (SP2)
Intel i7 930 2.8Ghz
2.99 Ram
ASUS x58 M/B PT6 SE
ATI Radeon HD5450
O/S on Kingston SSD
Capture drive SATA 11- 456 GB
Using Onboard sound ( no 3rd party sound card installed)
Would appreciate any tips
Cheers
03-13-2024, 07:24 AM
Your have the wrong VirtualDub timing settings. Post a screen cap of them.
03-13-2024, 08:09 AM
Virtual Dub Timing Settings
03-13-2024, 08:29 AM
Virtual Dub Timer Settings
05-22-2024, 05:25 AM
Following up from this thread from 70 days ago.
Still experiencing audio warping and freezing on playback
I’m venturing into capturing through Virtual Dub rather than the MPEG 2 Route (which has always been successful)
When it comes to setting up the ATI WONDER 600USB in Windows XP SP2 through the Control Panel the SOUND options on Play Back and Record gives me two options on selection.
1 Onboard Motherboard Sound Device
2 ATI
Can anyone advise where I’m going wrong, is there some sort of conflict happening between the motherboard sound and the USB device?
Thanks Tom
05-22-2024, 09:19 AM
Make sure audio monitoring is turned off during capture.
05-22-2024, 12:06 PM
Hi,
I’ve got selected under the Audio Tab in Virtual Dub
Enable Audio Capture
Volume meter
0 Capture device
Is that correct ( produces audio warping?)
Cheers Tom
05-22-2024, 12:10 PM
Gary34 Gary34 is offline
https://www.digitalfaq.com/forum/vid...-settings.html
I wonder if you should uncheck the bottom one.
05-22-2024, 12:51 PM
Originally Posted by badonica View Post
Hi,
Volume meter
0 Capture device
Cheers Tom
I said audio monitoring, not audio capture.
05-22-2024, 01:10 PM
Apologies, I will go through Virtual Dub settings and find “Audio Monitoring”
Ref my previous post I can’t uncheck “Capture Device”, I have to select something ( it’s the only one that works”
Thanks for your help
05-23-2024, 11:26 AM
You need to change the option from "resample the audio to a faster or slower rate" to something else. Resampling the audio causes a pitch shift. I don't know why anyone ever thought that was a good idea!
05-23-2024, 12:17 PM
In your timing settings with this OS and this card I believe that you are supposed to uncheck the bottom box that says force audio clock when audio playback is enabled based on the link I sent above.
05-23-2024, 03:56 PM
Thanks for the guidance - really appreciated
Cheers
05-23-2024, 03:57 PM
Thanks for your help - really appreciated
Cheers
The following users thank badonica for this useful post: Gary34 (05-23-2024)
AFM Audio into VirtualDub? Mack Capture, Record, Transfer 7 11-26-2021 09:59 AM
Why is my audio desyncing in VirtualDub? bideobeard Capture, Record, Transfer 20 09-20-2021 07:45 PM
VHS audio issues when using VirtualDub? MechVHS Capture, Record, Transfer 15 08-23-2018 04:45 AM
Problem with ATI TV Wonder 600 USB in VirtualDub - no audio? Zoink187 Capture, Record, Transfer 7 07-21-2014 04:26 AM
No audio when capturing with VirtualDub TylerDurden389 Capture, Record, Transfer 17 04-15-2014 05:27 PM
