04-27-2024, 07:45 PM
Feedbucket Feedbucket is offline
Was doing some test capturing earlier today using my AIW 2006 on XP and left VirtualDub in Capture mode as I stepped away for an hour or two. Came back, swapped some wires, and now I can only get this (see attached). Is this a hardware failure? My VE PCI still seems work OK and the source works fine when connected directly to a screen.
04-28-2024, 04:50 AM
KhAoS182 KhAoS182 is offline
The S-Video cable is incorrectly connected or "dancing" in the connector.
07-03-2024, 08:10 AM
Yeah, I'd seen similar before and feared it was some kind of connection issue, something specific to the S-Video input, since the connections were all solid otherwise and all of the other I/O (RCAs in, VGA out) were still working. Turns out it was an issue with the card - I sourced a replacement and it works fine now. Fortunate since the cards are a lot easier to replace than the breakout connectors are.
Wanted: ATI AIW 2006 dongle Dan316 Marketplace 3 01-30-2022 03:52 PM
ATI AIW 2006 PCI-E, yes or no? SuperS Capture, Record, Transfer 3 08-04-2018 09:55 PM
No TV ATI All in wonder 2006 pcie MMC kennyb Capture, Record, Transfer 0 04-28-2012 11:48 AM
Server outage information [2006] admin General Discussion 0 03-11-2006 04:06 PM
