07-14-2024, 12:03 PM
IfyL IfyL is offline
Does every vcr (with DIGITAL dropout compensation) turn off the feature when NR is enabled?
I attached a sample here where i'm flicking between 3d-dnr on and off.
Both features are very useful when you want a direct lossy capture, but it's sad that dnr can't be enabled, otherwise you may get dropout lines. (the doc doesn't remove all and large dropouts, but most).
Also with dnr disabled, there's more vertical jitter on tapes with lots of dropouts (using es10 passthrough), plus sometimes the compensator picks up noise as well like in the sample, so them not working together is pretty problematic.
07-14-2024, 01:55 PM
Just found out that re-insterting tape not in the beginning, but a bit further fixes the problem, though it's not the best solution.
Toshiba M-641 VCR powers on, but doesn't work? gronke Video Hardware Repair 10 01-13-2024 07:02 PM
Pinnacle 800i doesn't work? jrmymllr Capture, Record, Transfer 7 11-30-2023 02:33 PM
Datavideo 1000 doesn't work with JVC DR-M10? crissrudd4554 Capture, Record, Transfer 11 10-23-2023 01:32 PM
ATI 600 card doesn't work in Windows 7, how to use? newby Capture, Record, Transfer 56 05-08-2017 10:34 PM
Help with External TBC, Noise Reduction, and dropout compensator to fix VHS tape via Email or PM Restore, Filter, Improve Quality 3 06-29-2010 09:45 PM
