07-29-2024, 08:01 PM
mike919 mike919 is offline
Another day, another problem
I recently noticed that in the background, there is some unnecessary background noise.
It looks like it isn't apart of the actual VCR.
I think this is a S-VIDEO cable problem or interference issue - If not, can someone explain this odd problem?
Screenshots / Videos provided are examples from two different capture devices
- Dazzle DVC 100 (Revision 1.1) (PNG)
- ION VIDEO MKII (PNG/MP4)
------[[THE AUDIO ON THE .MP4 FILE IS GLITCHED FROM STAXRIP - HEADPHONE WARNING]]-------
mike
07-30-2024, 09:04 AM
Don't judge by the menu, play an actual tape contents, Most VCRs exhibit dot crawl in the menu or in the blue screen in the absence of a video signal.
07-30-2024, 11:17 AM
No no, it happens while playing VHS too. Its just more visible while in the menu.
mike
07-30-2024, 11:57 AM
Here is a clip from a VCR that shows the issue even more. Not much dot crawl, but it is still visible.
I didn't use a TBC on this because I wanted to keep the signal original, and not have it passthrough a DVD recorder.
Edit: Yes, this is from a composite clip, but this happens on S-VIDEO too, its just a little more faint.
07-30-2024, 03:33 PM
I don't see dot crawl in the video. Unfortunately, that's the quality of your tape, VCR and capture device or a combination of them, You can replace each one and see which one is the culprit, But overall and besides the interlacing effects and line timing errors, that's how analog video should look like.
07-30-2024, 04:07 PM
So I am delusional
mike
07-31-2024, 01:16 AM
I wouldn't call it delusional, but you are expecting too much from an obsolete video tape format, Get the line timing fixed and do a proper de-interlacing, it should look better.
07-31-2024, 01:22 AM
Haha, that delusional part was just kind of a joke. You are definitely right, I am expecting too much from too little.
Line timing, yes I will work on thank you for the recommendation
That was just pre-processed footage. I do definitely de-interlace later.
Even though its just a standard analog signal, I zoomed in more of what I was talking crazy about.
But, thanks for the help either way
#vcr #static
Annoying background sound on JVC S-VHS VCR? shinichi999 Video Hardware Repair 18 05-07-2023 11:42 PM
Background music for YouTube videos? mattminaj Videography: Cameras, TVs and Players 11 01-08-2019 08:45 PM
Background Image In Table... naimeiiz Website and Server Troubleshooting 0 08-05-2011 05:03 AM
How to add background music in Ulead DVD Workshop 2 Superstar Author, Make Menus, Slideshows, Burn 1 07-28-2009 07:28 PM
Adding background music to the DVD menus Superstar Edit Video, Audio 2 07-19-2009 04:52 PM
