06-03-2009, 11:01 AM
Superstar Superstar is offline
For videos that I will NOT be encoding in MainConcept, what different bitrates should I use?
For example..as I mentioned a few posts ago, this is what I use when I capture for a video that I do encode "for when I capture, (everything I capture is 2 hrs 30 min - 3 hrs) the bitrate that Im using is Constant Bitrate, 15,000 bitrate, No Bitrate Peak and 720x480"
For a video that is about 2 hrs long and I WILL NOT be encoding it in MC, should I use Variable bitrate, 4,900 bitrate, 5,900 bitrate peak? Does that sound about right?
06-04-2009, 08:59 AM
Yeah, that sounds about right.
Recording Wii with USB capture card ? via Email or PM Capture, Record, Transfer 1 07-24-2009 08:35 PM
Looking for used capture card naga Capture, Record, Transfer 6 07-07-2008 09:52 AM
Capture Card or Recorder fortunec00kie Capture, Record, Transfer 10 02-25-2007 03:54 PM
Q: capture card or dvd recorder? manthing Capture, Record, Transfer 5 03-18-2006 05:46 AM
Capture card Wineslurper Capture, Record, Transfer 6 07-12-2005 08:04 AM
