03-18-2026, 06:51 PM
ddybing ddybing is offline
Hi there.
I am setting up a small workflow to digitise my tapes.
I am using a Panasonic DMR-EH57 as "TBC-ish" passthrough from my S-VHS machine.
The only issue I am having is that the audio is clipping hard (or at leat sounds "blown"/distorted) on the output of the DMR. If I plug the audio from the VCR directly into the TV, it sounds fine.
Anyone know what that could be caused by? The audio is distorted on both the analogue outputs as well as on HDMI.
03-18-2026, 08:50 PM
radiokom radiokom is offline
Clipping where? If at capture card it commonly means level exceed 0dbfs.
Did you tried to connect DMR audio output directly to amplifier and measure output level?
If clipping is at DMR output it probably means there is analog/digital conversion inside what is defective.
But what kind of distortion you have - is it clipping or something else is impossible to tell by your description.
I am not sure DMR-EH57 can be used as "TBC-ish" like ES10/15 but maybe.
03-19-2026, 04:39 AM
Hi again
What I meant is that the audio sounds clipped/distorted, as long as it goes through the DMR. It sounds the same on the analogue and HDMI outputs. However, if I take the audio jacks from the VCR and plug them straight into a TV, it sounds fine. It's only when listening to the output of the DMR that it sounds distorted.
I have an audio attenuator in-line (I've tried without it as well) but thatt doesn't seem to reduce the distortion, it just lowers the actual volume (so distortion/"clipping" must be happening somewhere else).
I have attached a small captured segment, however please note that it sounds exactly the same when listening to it on a TV that is connected via the DMR.
03-19-2026, 06:49 AM
timtape timtape is offline
Attenuating the gain was a good test. Unfortunately Panasonic were at one stage supplied with some pretty poor quality capacitors which may be the problem here in your deck.
03-19-2026, 06:50 AM
The SCART inputs on the back have also given up, I get no audio or video there any more. So I'm thinking this is a defective unit, and am now looking for a replacement.
Thanks for the input.
03-19-2026, 07:59 AM
I have ES10 with recapped PS, not far from your country, PM if interested.
Panasonic DMR-ES15 Passthrough for JVC DR-M10? ddw_119 Capture, Record, Transfer 6 11-04-2021 09:59 PM
ATI 600 USB audio clipping? someperson Capture, Record, Transfer 2 08-04-2016 11:07 PM
Fixing clipping audio in MP4 video? summergleason Restore, Filter, Improve Quality 5 12-04-2013 04:32 PM
How to adjust very loud audio clipping during capture? moxiecat Capture, Record, Transfer 6 03-07-2012 05:37 AM
My Other High-End VCR, the MITSUBISHI HS-U70 (with audio output clipping problem) Tasuke Videography: Cameras, TVs and Players 0 05-13-2011 01:56 PM
