12-07-2024, 02:57 PM
meljr meljr is offline
Hi! Long story short, I have some French pre-records that I want to capture as native SECAM. Maybe it's ridiculous - I have PAL captures that are fine for what they are - but I wanted to properly document this information since it's seemingly quite obscure, even on this forum. I'll update this post as I go.
Anyway, as others have said, there don't seem to be any SECAM-compatible decks with line TBC. You're just stuck on that one. I'd imagine lordsmurf's guide for SECAM is about is authoritative as it gets. I bought a Samsung SV-5000W when I got in a hurry and forgot that it can't handle SECAM-L. I thought I had flushed US$250 down the toilet. It turns out I didn't, and I'm getting some interesting results.
If anybody out there has SECAM pre-records, you should be able to save some money and pick up the AG-W2 / HV-MX100 / SV-5000W. They're relatively cheap compared to the other recommended decks, and more importantly for my purposes, I don't think SECAM pre-records use SECAM-L. (The ones I own don't use it, at least!) I think I read somewhere that many SECAM pre-records, if not all of them, are not SECAM-L. So far, that seems to be true. When I pop in my tapes and force PAL output, I get perfectly acceptable picture and audio. If I pass through the signal, the tape plays but my cheap composite-to-HDMI converter produces a funky picture. It's technically watchable, just black-and-white-ish with a slightly flickering picture.
My next step will be running a tape through my capture gear and seeing what can handle a native SECAM signal. I don't think my TBC-1000 will handle it but the AVT-8710 presumably will if I ever pick one up. I don't know about my capture card. I'll poke around and see if I can find any good ones that can handle SECAM. I'll either edit this post or add some replies as I go along.
I make no promises regarding your pre-records, dear reader. I'm just saying that if you're not dealing with SECAM tapes made from French TV or whatever else was known to use SECAM-L, it shouldn't hurt to give the AG-W2 / HV-MX100 / SV-5000W a try. Who knows, maybe if you're really adventurous, you can mod it to work with vhs-decode (Domesday86-related) and try to add TBC later. (I've lost track of where that team is at with their TBC work, and I have no clue if it's SECAM-compatible.)
Thanks.
Good news: I popped in a tape and ran the VCR through an ATI AIW USB clone and into VirtualDub. After setting the capture to SECAM-B and fiddling a bit with the capture setup, it worked! I can capture a pure SECAM signal and have it look right. There may be other capture cards that aren't ATI / ATI clones and can handle SECAM. I'm just saying that recommended ATI hardware should be fine.
(The picture is a bit "snowy" but that's a project for another day. I know it's not the tape because somebody with an SV-7000W that he had just serviced made a PAL-converted transfer for me last year. The picture isn't snowy at all.)
12-07-2024, 05:33 PM
As far as I know, legacy capture cards and pro devices are the only ones that can handle SECAM properly, none of the modern or chinese stuff would work, SECAM chroma is a nightmare, this is why the French territories that used SECAM before dropped it in favor of PAL and MESECAM for consumer camcorders. The JVC S-VHS SECAM machines should handle SECAM if you have the right capture device, Albeit no line TBC as I've read.
Colin from video99.uk.co YT channel made a video about machines that playback SECAM properly, you should check it out.
12-07-2024, 06:09 PM
Heh. If you're talking about the video he posted last year, that's one of my tapes in the background. I'm pretty sure he had the VCR convert to PAL before capturing. I might be wrong. I'd have to go back through the correspondence.
In any event, I think if I can get the snow fixed (I'll post a sample later), I'll be happy with what I have. Tracking down a good JVC S-VHS SECAM deck that's confirmed to not be broken seems like far more trouble than it's worth, especially since line TBC will be turned off. (That said, I do have an HR-S9700 coming soon. Maybe I'll give it a try just for laughs.)
12-07-2024, 06:32 PM
For a long time i worked with a Terratec 250 pci card on XP (win7 aswell) that can handle secam B/L, PAL/NTSC60 amongst others that i've personnally tested.
Secam B for retail tapes (sold in france) / Secam-L for tv recordings.
I did my research a while back but gave up acquiring one of them given the high price and/or scarcity:
* The ACE converter Box handles Secam
* CTB-100G (which is a clone of the AVT 8710 handles Secam->Pal) ( online manual HERE
* Cypress CDM-800 handles Secam -> Pal
Video Mixers:
CMX 112 (handles all formats, Hdmi,yuv,composite,s-video in/out etc..) more infos HERE
cost ~ 2750€
Also supposedly a high end Toshiba DVD/HDD combo (Toshiba-rd-xs32) but the seller did not confirm this to me so i don't believe it (i mean the TBC part that handles secam)
Now i'm impatient to see your Ugly Secam caps ! Héhé
12-07-2024, 07:15 PM
aramkolt aramkolt is offline
Looks like all of the "analog input" Snell and Wilcox standards converters and TBCs (The TBS line - Timebase Stabilizer as they call it) will take SECAM - but in most cases the output will need to be PAL in the form of composite, S-Video, or SDI. However, the full size rack-mount units can accept SECAM OR convert anything TO SECAM. Examples of those are the CVR250/450/550. I am also pretty sure that their standards converters all contain TBCs as well. In some or possibly all cases, they are both line AND frame TBCs, but I haven't gotten that far in my testing to say for sure.
12-08-2024, 07:39 AM
On the cheap side of things, i can use my transcoder secam->pal on the jvc hr-s7700ms (or 8600ms)
https://imgsli.com/MzI0OTk0
note: The chroma noise reduction is essentially made by a sony rdr-hxd 890 at the end of the chain
Some jitter is reduced
Colours remain about the same to the naked eye (this is a tv recording, Secam-L, no macrovision)
File Type: jpg VHS-SECAM-Panasonic-JVC7700-DIRECT_OUT-img_2.jpg (273.9 KB, 10 downloads)
File Type: jpg VHS-SECAM-Panasonic-JVC7700-PAL_OUT000002.jpg (244.5 KB, 10 downloads)
12-08-2024, 11:23 AM
Hi! Thanks to everybody who has been replying. I appreciate it and will try to get a proper reply up later today.
Quick update: My HR-S9700 came today. (I said it'd be soon!) I got excited when I skimmed an online manual and saw that there was a claim regarding the deck's ability to play SECAM-B tapes. (SECAM-L was explicitly marked as not compatible.) With the caveat that I skimmed and may have missed important info (menu setting, specific model, etc.), it looks like it's a no-go for SECAM. The tape plays but, as expected, it's black-and-white. I tried capturing as both SECAM and PAL in VirtualDub. No dice. There may be JVC S-VHS decks that can either output a clean SECAM signal or transcode to PAL. I'm just saying mine doesn't do that. :/ Either way, it did confirm that my 5000W needs a bit of TLC to get rid of the snow. I'll post a sample later and see if anybody can suggest a fix.
Thanks.
12-08-2024, 06:36 PM
I think you are mixing between TV standards and VHS standards, SECAM on VHS is just SECAM and yes it is a.k.a SECAM L, What you think is SECAM B is probably no other than a MESECAM tape format, SECAM tapes play in B&W on PAL only VCRs, Not sure where you live but if you want to send me one of these SECAM B tapes I can help identify it since I have a VCR capable of reading native NTSC, native PAL, as well as MESECAM and NTSC 4.43.
But as far as native SECAM tapes, you can't play them back without a native SECAM VCR.
Edit:
Poking around, I think from this post it looks like MS letter designation is for SECAM VCRs that are capable of playing back MESECAM tapes. The S designation is for VCRs that can only playback SECAM tapes.
As far as TBC for SECAM/MESECAM, it appears that it is not possible from this post, It makes sense because of the nature encoding of the SECAM chroma, it is too complicated to build a chip that digitizes and converts back to SECAM without an added cost to the build, However it is confirmed here that if you set a -MS VCR to convert to PAL, it will take advantage of the line TBC.
01-01-2025, 07:58 PM
@latreche34 - I'm pretty sure my tape is a proper SECAM tape. Maybe it's just me but it'd seem odd to manufacture MESECAM pre-records and sell them as SECAM tapes in France. Anyway, thanks for all the other info. That basically lines up with my understanding.
On a related note, does anybody know the technical reason for why the 5000 won't play French tapes (presumably over-the-air recordings since it plays my pre-records just fine in passthrough mode)? I wrote something here about vision modulation but realized it's probably wrong, so I deleted it. Maybe I missed something but I can't seem to find the specific technical reason why it doesn't work. As best I can tell, it's some sort of audio carrier and/or chrominance/luminance issue.
Thanks.
What would be the best VCR for capturing SECAM tapes? plem8 Capture, Record, Transfer 8 12-11-2022 01:16 PM
VHS cassettes recorded in SECAM and capture in PAL? dima Capture, Record, Transfer 1 08-20-2019 11:54 AM
Pre-recorded D-VHS tapes for sale [SOLD] latreche34 Marketplace 1 02-23-2019 01:01 AM
Problem capturing Secam with ATI AIW? Mejnour Capture, Record, Transfer 5 11-07-2018 03:38 AM
Capturing miniDV recorded with misaligned heads? photoguy1234 Capture, Record, Transfer 2 01-14-2018 11:44 PM
