03-05-2025, 02:55 PM
Jamestq Jamestq is offline
Hi im just comparing Hi8 footage I captured first using a digital 8 camera via firewire and then using a capture card via s-video. I like how the color and noise is much better but i'm really confused as to why the aspect ratio is so zoomed in on the S Video captured video. Notice how there is image data missing to the left and right of the fridge and the image looks ugly and stretched. the DV captured images scale looks true to life and there seems to be more data there but the color and noise is worse.
Can someone educate me, what's going on?
I know that lossless AVI does not have an aspect ratio so i set both videos to 4:3 in VLC and both videos are 720x480
Thank you.
03-05-2025, 02:57 PM
Here is the image not sure why it isn't showing in original post
03-05-2025, 03:06 PM
This is probably your capture card, You may want to try a different capture card or a TV with analog input that has the capability of "just scan" to show the entire video frame. Some capture cards crop automatically to 704 and rescale to 720 on the fly, Not sure why, but if you have one of those cards just toss it.
Lossless AVI don't have an aspect ratio, you set your aspect ratio during encoding to the final format.
03-05-2025, 03:14 PM
This is super embarrassing... I was using crop in vlc by pressing C instead of changing the aspect ratio here is the new image, do you think that looks identical? lossless is on the left.
I'm using an All in wonder 9000 card.
DV capture is definitely brighter in the shadows
Thanks for replying sorry to waste your time.
03-05-2025, 03:50 PM
Looks about right, The levels on the lossless can be adjusted in the card's proc amp, It is difintly too dark.
aspect ratio, lossless vs dv
Jumpy/glichty image when capturing VHS to PC, is it the video grabber? Vanda92 Capture, Record, Transfer 1 04-14-2021 01:52 PM
VirtualDub no image, but capturing works? Hackerpcs Capture, Record, Transfer 13 07-22-2020 06:41 PM
Capturing Workflow - from VHS to lossless for later editing hecky Capture, Record, Transfer 11 04-04-2020 06:21 AM
Image lines problem capturing from VHS? judge Capture, Record, Transfer 13 02-29-2020 09:39 AM
Hauppauge video capture is lossless? dinkleberg Capture, Record, Transfer 5 08-26-2016 12:19 AM
