Hi, bringing this one up again as I'm making (slow but steady after 9 years!) progress.
Here's what I generally do with my VHS captures (AG1980 or HR-S9800U, DataVideo 3000 TBC, ATI600)
- Capture with
VirtualDub 1.9.11 on XP, 720x480, losslessly compressed and saved.
- Moved to Windows 11 (monitor calibrated with datacolor SpyderX Pro).
- Check histograms, crop and add borders (vdub, avisynth)
- Adjust color, darks, lights with ColorMill (in vdub) and/or ColorYUV, Tweak, Levels (vdub, avisynth)
- denoising, degrain, sharpen - lallo's script (vdub, avisynth).
- Inverse Telecine or QTGMC depending on what I have (vdub, avisynth).
- If it's going to YouTube, upscale to 1920x1440 - lallo's script (vdub, avisynth).
- Hybrid to convert avi to x.264.
So, back to my year old question. Should the bitrate, which defaults to 1500 kbits/s, be set to 25000 kbits/s?
Obviously that makes the file much larger. So I want to be sure and am curious what others do here.
And yes, I plan to slowly convert to using Hybrid for many of the above steps. Just taking it one step at a time!
