04-16-2026, 01:07 PM
BmacSWA BmacSWA is offline
I've been looking for es10 and es15 units to add to my workflow. If i'm using it as a passthrough, are there functions or settings I would not be able to access if the unit came without a remote or is everything I need available with just the buttons on the unit?
B
04-16-2026, 09:25 PM
radiokom radiokom is offline
Input select button and menu. But you can use remote from later models.
This for example:
https://www.ebay.com/itm/178018141167
Or this, I believe, should work:
https://www.ebay.com/itm/124137832118
04-17-2026, 11:57 AM
ES10/15 remote models can get screwy. Not all work, even when they should.
04-17-2026, 01:54 PM
Or ES receiver can be faulty most likely. My experience with Panasonic remotes - if they has appropriate function knob, it works for all Panasonic devices. Input switch is essential. Menu - for switching between PAL/NTSC. Maybe there is secret combination of panel buttons to do it, but I do not know.
04-17-2026, 02:05 PM
Ah, yes, I forget that.
A lot of these "doesn't include remote" Panasonic units, as soon as eBay/Facebook/etc, no longer work with any remotes. The receiver/eye was a common failure point on these units. This forum has seen quite a few of those type of posts going back 10-15 years now.
As always, random buying gear is so full of pitfalls.
@BmacSWA, I have an extra unit here, if you want to get it. (And I see eBay pricing now exceeds what I charge. Mine are modded or refurb'd, theirs are just random yard sale finds. Terrible. I guess ES10/15 is getting the SSD pricing treatment.)
04-17-2026, 02:11 PM
cbehr91 cbehr91 is offline
I have a perfectly working ES10, except the IR sensor died many years ago. Has anybody replaced it; and if so, how difficult is it?
Panasonic DMR-ES15 needed for VHS/Video8 conversion? woko2 Project Planning, Workflows 5 11-02-2025 09:18 PM
Panasonic DMR-ES10 or ES15? Bester Capture, Record, Transfer 4 06-22-2025 01:14 PM
For Sale: Panasonic DMR-ES15 DVD recorder TBC w/remote [SOLD] ridzoman Marketplace 0 04-16-2019 05:28 PM
JVC HR-S9911U and Panasonic DMR-ES15 remote for sale [SOLD] history1 Marketplace 5 01-04-2015 08:35 AM
