04-18-2026, 09:40 AM
KirVHS KirVHS is offline
Hello once again.
Im using Pinnacle Dazzle as everyone know, so i got a dot crawl problem witch i tried to fix via Hybrid.
But that was unsuccessful.
I just need to fix this trouble...
And yep the recording on LP speed.
04-18-2026, 04:08 PM
https://en.wikipedia.org/wiki/Dot_crawl
04-19-2026, 03:50 AM
Originally Posted by themaster1 View Post
It seems i got Chroma dots (Hooray to MESECAM/PAL)
04-19-2026, 05:25 PM
mts1 mts1 is offline
If you use composite cable anywhere in your chain, you might need to start using S-Video connection.
04-20-2026, 11:12 AM
Unfortunately, i could not have an access to perform this (SCART ADAPTORS arent count)
And they are ruining the capture quality
04-20-2026, 11:22 AM
Actually, SCART adapter would not be that bad. I'm talking about a dongle which has male connector to SCART to connect to your VCR socket and female socket to plug in your S-video cable.
Assuming, of course, your VCR support S-Video over SCART.
Also, it doesn't guarantee it will solve the problem. Dot-crawl might be already recorded on your tape.
The following users thank mts1 for this useful post: lordsmurf (04-20-2026), un_kbron_del_664 (04-21-2026)
04-20-2026, 12:05 PM
I already got it, but it getting a worse result when recording a MESECAM recordings
amarec_20260420-191759 - Direct Composite
amarec_20260420-191817 - SCART adaptor with SVideo
04-20-2026, 12:11 PM
Double check your setting for your SCART in VCR set to S-Video, not just Video.
Btw, all your attached png files give me empty white rectangle.
04-20-2026, 12:13 PM
Jeez... this is cuz amarec is giving me .bmp not png...
And how i could check this at my Samsung SV-DVD 645P?
04-20-2026, 12:21 PM
I'm not familiar with that device, but usually you call the menu and browse it.
Look for connections, input/output settings. They might call it AV1, AV2 etc.
By default this setting is set for Video. It means your luma wire of S-Video connector gets a mixture of luma and chroma (composite signal) and you chroma wire gets chroma. I've seen that before. Dot-crawl is given in that scenario.
04-20-2026, 12:24 PM
Do you got any social media?
I could send the result of this (It worse at any case no matter what i set)
04-20-2026, 12:36 PM
That's not needed.
Put the images in a .7z or .zip file, attach that here.
04-20-2026, 12:37 PM
That's not needed.
Okay i'll do it right now
04-20-2026, 12:40 PM
That's not needed.
Here it is.
04-20-2026, 01:16 PM
Don't you have S-Video jack on the back of your SV-DVD645P?
04-20-2026, 01:54 PM
I have only for DVD output
04-20-2026, 02:20 PM
Have you tried playing VCR and connecting S-Video?
Anyways, the setting for the SCART from your menu:
DVD -> Display Setup -> DVD Out -> S-Video.
Something tells me if you can get S-Video from the SCART, you should have in from S-Video jack too.
Good luck!
04-20-2026, 02:41 PM
Good luck!
Nah, same result even if i connect to dvd jack it will stuck in DVD menu
04-20-2026, 02:46 PM
So, where you able to switch SCART to S-Video?
04-20-2026, 10:19 PM
You mean I need to connect to SVideo Jack instead of SCART?
Well I did already, and I described what result I’ve got
Is this dot crawl? (new VCR comparison) tbgconnor Capture, Record, Transfer 5 09-03-2021 12:24 PM
Best scripts for dealing with dot crawl? ofesad Restore, Filter, Improve Quality 0 06-16-2021 03:39 PM
Dot crawl and shimmering in red areas? Master Tape Restore, Filter, Improve Quality 8 11-13-2020 03:45 AM
Avisynth slows VirtualDub to a crawl? Hushpower Edit Video, Audio 3 09-28-2020 06:13 AM
Removing dot crawl with Avisynth? (1st attempt) TheCatacomb Restore, Filter, Improve Quality 7 06-13-2016 10:35 PM
