Today, 03:20 PM
goznevi goznevi is offline
Originally Posted by MediumDave View Post
Which drivers are you using to use the Matrox MX02 under Windows 10? I have an MX02 Mini, and the most recent driver for it was for Windows 8 64bit.
I’m using the Matrox 8.x drivers under Windows 10 LTSC 2019. They work well, but compatibility depends heavily on the Windows build, motherboard, and BIOS. Some Windows updates can break the drivers, so I keep the system stable and avoid updates. If the MXO2 is not detected, it’s often a bios or Windows 10 version rather than the driver itself.
The driver has to be installed in a fresh install windows 10 and has to be the first think that you install.
Today, 04:33 PM
MediumDave MediumDave is offline
LOL, that's very much par for the course for a Matrox product. I still have a Digisuite that's hilariously finicky about system specs. I have the version 8 tools, but didn't know that they were compatible-ish with Windows 10. Thanks.
aiw, aja lhi, ati, matrox mxo2, x1900
How to capture poorly for comparison purposes? Haunted_TBC Capture, Record, Transfer 21 11-16-2025 03:23 AM
Capture comparison quality issue? Jayce72 Capture, Record, Transfer 1 06-07-2023 03:37 PM
Capture formats (archival): MiniDV, DV-AVI, 8mm tapes? nicholasserra Capture, Record, Transfer 13 10-01-2017 08:21 PM
Is MJPEG capture good enough for VHS archival? n1000 Capture, Record, Transfer 9 07-31-2016 04:26 PM
VHS Capture & long-term archival suggestions... naripeddi Project Planning, Workflows 4 12-08-2011 10:06 PM
