10-18-2005, 07:54 AM
padre2 padre2 is offline
Wanted to get people's opinion of recording/viewing preferences. I just recently built a new PVR to dedicate to my DirecTV HD receiver (H10). It won't be recording in HD format, because I'm using the S-Video connection and it downshifts the resolution, but the signal is crisp and clear.
My question is: Should I record most things in the Widescreen format (16:9), or is standard preferred (4:3)? I did a couple of sample recordings, including "Two and a half Men" and I was suprised how many little odds and ends I saw in widescreen that I didn't see in standard. But since most people have standard screen TVs, they would get the black areas at the top and bottom.
Thoughts? I was thinking for shows like Alias, and other action series, do in widescreen. But comedy/drama, do in standard?
10-18-2005, 10:43 AM
Well, if you record as proper 16:9, then a DVD player will play it back with wide bars on tv. Personally, I like to see all the picture, and if that means I have to have black bars on the top and bottom to do so, then so be it.
If people don't like it, they can use the ZOOM function of the DVD player to make it fullscreen. Assuming they have a good players, as I know some of the crap cheapies don't have very good zoom functions. My Toshiba works well, I usually zoom in halfway on a lot of movies on my bedroom tv, cutting of some of the sides, but still partially widescreen.
So, basically, if you want it widescreen, go for it.
This is one of those instances where you need to remember you do the hobby for yourself, so whatever makes you happy. Pick what you like better.
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
Your opinion on a couple of product models? admin Capture, Record, Transfer 5 08-26-2009 05:07 PM
Can someone make a Widescreen PSD Overscan? Konfusion Author, Make Menus, Slideshows, Burn 7 06-15-2009 07:25 AM
Encoding an XP (1 Hour Mode) MPEG to SP Mode shadowkaos Encode, Convert for discs 2 10-30-2007 09:29 AM
Panasonic 4-hour mode illustrated lordsmurf Capture, Record, Transfer 2 09-12-2005 06:47 AM
