09-24-2011, 12:18 PM
JLegnon JLegnon is offline
I've tried lots of different MMC versions but whenever I try to use the TV , I always get this message , "Unable To Start TV" .
Some of the MMC versions have a self Test feature , so I run that and it says "DirectX not installed properly" and "Capture Driver INF files are not installed" .
I'm running DirectX 9 . Its says to install , DirectX 8 , so I do that and then it says install DirectX 9 , it goes back and forth .
As far as the Capture Driver , I'm pretty sure its installed correctly . I have a X800 series card and I have been using the Catalyst Installer , I've used different versions , but right now I have 8.12 installed .
10-02-2011, 05:37 PM
Ignore any advice to install DirectX 8. In fact, if you're being asked to install dX8, then you're using an extremely outdated installation disc. The x800 card likely requires ATI MMC 9.14 or higher, and the CCC (Catalyst) installer.
I've added these files to this post: http://www.digitalfaq.com/forum/vide...html#post17586
Install these, in this order:
  1. 10-2_legacy_xp32-64_dd_ccc
  2. 10-2_legacy_xp32-64_wdm
  3. 9-14_mmc_uci
  4. 9-14_mmc_enu
  5. 9-16_mmc_enu
First one is the Catalyst CCC.
Next is the WDM drivers.
The ATI MMC libraries/misc files to run ATI MMC -- the UCI files.
Finally, install 9.14, then install 9.16 over 9.14. (Note: It may be possible to skip 9.14, but I forget.)
I would imagine this works the same on the x800 card.
10-03-2011, 06:21 PM
Thanks for the help , It worked ! This site is a great resource for information and help . So I paid to be a
The following users thank JLegnon for this useful post: lordsmurf (10-03-2011)
10-03-2011, 06:25 PM
Excellent, glad to hear that did the trick.
And we thank you for supporting the site by becoming a Premium Member.
Recommendations to transfer video from capture PC to main PC? GroverXpup Project Planning, Workflows 3 11-24-2017 05:13 PM
Solved: Locate command not working in Linux SSH, "No such file or directory" kpmedia Web Hosting 1 07-25-2011 04:30 AM
Add HTML option to vBulletin 3.x "Send Email to Users" admincp admin Website and Server Troubleshooting 0 04-28-2010 08:29 AM
