02-05-2015, 03:22 AM
rocko's Avatar
rocko rocko is offline
I already have had ATI AIW 9600XT and MMC set up, and installed/working fine on XP AGP/PCI PC w/ Sound-blaster card (Including ATI break-out cable). Just wondering, if I R&R existing AIW card with another, similar AIW card, would it be a simple plug-n-play replacement, or would I have to re-install any ATI software, or re-set-up anything on XP system?
02-06-2015, 11:39 PM
If it ain't broke, don't fix it. Don't screw around with a good AIW setup that's working perfectly. You may regret it, have all sorts of issues, and be back at square one (no capture setup). Don't do that to yourself.
The following users thank lordsmurf for this useful post: rocko (02-07-2015)
02-07-2015, 12:08 PM
rocko's Avatar
Yep, your right again Lordsmurf!..After setting everything back-up for capture, and Neatly bundling/routing cables, I Found a loose S-video cable going from the ATI break-out to the AV-Toolbox, causing what looked Just Like RF Noise on the Toolbox color bar screen!..Don't need to mess with card at all!!
Replacing VHS Tape Cassette Winsordawson Capture, Record, Transfer 9 01-27-2013 04:30 PM
Replacing a header with an image via CSS only, not HTML code Sossity Website and Server Troubleshooting 1 11-10-2011 09:48 PM
Help replacing FS200 video head? zeroprobe Video Hardware Repair 9 04-02-2011 04:26 AM
