Unfortunately, I have found that having audio playback is enabled or muted produces the same results. The key problem seems to be length. Anything recorded in around a half an hour or so won't lose sync, but longer ones will.
I have tried using both the VDub with presets from this forum (1.91 I think) as well as the 64 bit version of it. Same problems. And yes, I have installed K-Lite onto the machine. However, I have tried to bring them to another machine to see if I could use something to convert these AVI's to a playable format and have found that nothing I have tried will do it. Handbrake won't recognize the file at all and playback on VLC or Classic Media Player won't recognize the codec. I have also tried using Avidemux and I guess I just don't understand what I am doing on that one.
Screen caps have been the only thing that has worked since I started this project. In some respects, I wish I had continued with it because I wouldve been done by now. In others, I would not have been able to get some tapes to play at all using the equipment I was using from the start, so that content wouldve been lost. I'm really looking for something that will just work.
So again, my two problems are that I have some audio drift which you and I have tried to troubleshoot quite a bit to no success since I do not have access to a computer running Windows XP or for some other unknown reason. My thought is that it may be likely that I dont have XP is a strong factor since it is the only constant that hasn't changed since I started. I have tried multiple cards, have as clean a signal as I can with a TBC and a Panansonic and have tried different encoding methods from Huffy to Lag to even Xvid.
And again, the second problem is that the videos I did successfully capture cannot be either converted or played back on any other device. The point of this is to have them available to be played back by the family and archiving comes in a distant second. This is the reason I had suggested simply opening VDub and screen capturing the output with a different piece of streaming software such as Xsplit or OBS. This method may not provide the best quality, but it does work and converts it into a usable format. I guess I am simply trying to figure out if there is any other things I have not tried before I give up out of frustration and just do it in that way.
