06-11-2016, 12:15 AM
harky harky is offline
Hi,
i bought a VCR player which can playback true NTSC and bypass ES10 (set to NTSC also) it come out fine.
But the problem is when i cap using VirtualDub it has many drop frame, but no insert frame as what i notice
How do i solve the drop frame issue??
My desktop is running INTEL CORE I7-4770 SOCKET 1150 3.40 GHZ
06-11-2016, 12:18 AM
Thanks for the extra info. But one thread should be enough. http://www.digitalfaq.com/forum/vide...html#post44579
Otherwise you're going to be busy checking three threads with the same question in two different forums.
VirtualDub - constant frame rate vs. variable FPS? Zerowalker Capture, Record, Transfer 6 01-10-2014 04:02 PM
VirtualDub timing options? Frame drops with ATI 600 PCI card? frank_aspen Capture, Record, Transfer 18 01-14-2013 09:19 PM
Editing in VirtualDub is frame-accurate? naripeddi Edit Video, Audio 8 08-16-2012 03:14 AM
Frame drop every 100 seconds exactly awow69 Capture, Record, Transfer 3 04-14-2006 08:15 AM
