11-10-2016, 11:00 PM
waloshin waloshin is offline
How is this JVC HR-7900U operating? Captured with a Canopus ADVC 55 through S-Video.
https://drive.google.com/open?id=0Bw...00wLXZaUFZmOTA
11-11-2016, 04:17 AM
It's a shame quality took such a hit with phony image enhancement by capturing to DV, then another hit by re-encoding to a second lossy codec. It makes it difficult to judge whether the problems are due to the lossy codecs, the stablizer (which didn't seem to be stabilizing so well), or the JVC's "Auto" feature. The video looks plastic and over-processed with the typically "cooked" color usually seen with tape to DV. Knowledgeable video enthusiasts would find it annoying to watch, less discriminating viewers will be fooled into thinking that the artificial effects and compression losses look cool. Turn off the stabilizer and don't use anything that says "Auto" when capturing. Turning off the TBC obviously made things more unwatchable with bad shimmer, ripple, and increased noise and jitter throughout the images, something that even the visually challenged should be able to see. Most segments have illegal luma or chroma values for digital video, which is typical for uncontrolled DV capture. Other than the defects purposely inflicted onto the capture, the JVC seems to be working well. I wouldn't try using it with slow 6-hour or 4-hour tapes, but stay with SP retail tapes and the player itself should work well..
11-11-2016, 12:57 PM
Sounds good thanks.
jvc hr-7900u
VCR Manual Operating Manual Needed kater Video Hardware Repair 1 08-20-2011 10:03 PM
